Performance hood Seal
Old Sep 7, 2007 | 11:57 PM
CC5 Rider's Avatar
CC5 Rider
Default Performance hood Seal
I' m new to the Forum and this has most likely been discussed before. Does the performance hood seal work and what are the advantages of installing one.
Old Sep 8, 2007 | 12:05 AM
BATM4N's Avatar
BATM4N
About 7.37 more horsepower
Old Sep 8, 2007 | 12:07 AM
DefenderC5's Avatar
DefenderC5
Aww be nice to the new guy.
It keeps your engine bay cleaner, less dirt gets in between the hood and the bumper. You can make your own with home depot weather stripping.
Old Sep 8, 2007 | 12:14 AM
CC5 Rider's Avatar
CC5 Rider
Default Performance hood seal
Thanks for the info. Sounds like its worth doing.
Old Sep 8, 2007 | 12:57 AM
Last C5's Avatar
Last C5
It's so cheap that it is worth doing to keep the motor a little cleaner. The hood seals got laughed at a lot when they used to claim they would add horsepower - they don't.
Old Sep 8, 2007 | 10:01 AM
jrose7004's Avatar
jrose7004
It also helps keep water off of your perfomance air intake.
Old Sep 8, 2007 | 10:16 AM
rws.1's Avatar
rws.1
You can either buy the flat style weahterstipping you would use on a door or window at home you want about 3/4" width by 5/8" thick or you can buy the hollow "o" profile epdm automotive weather stripping from Autozone or other autoparts stores
Old Sep 8, 2007 | 10:38 AM
phoenixfoundmac's Avatar
phoenixfoundmac
That's the main reason I installed mine.
Old Sep 8, 2007 | 11:13 AM
CC5 Rider's Avatar
CC5 Rider
Thanks everyone, for the imput.
Old Sep 8, 2007 | 11:41 AM
mike348's Avatar
mike348
I did it to keep water off Black wing. You have tons of air coming through radiator to engine.
Old Sep 8, 2007 | 02:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I got mine from Auto Zone. Its from SOFT SEAL and it the exact same stuff that you pay an arm and a leg for on other websites. Theres enough in one package to do TWO hoods! You can split the cost with a buddy. I think it was $12 a package. It been a long time since I purchased it.
You will find out that its better to mount the seal on the UNDERSIDE of the hood rather than on the lip below the hood. When you raise the hood, you wont see it and it wont collect dirt in the lip of the seal as bad.
BC
Old Sep 8, 2007 | 09:53 PM
utryd2's Avatar
utryd2
It just keeps the dirt and water out.....
To Performance hood Seal
