Differential Fluid Refill
Old Sep 9, 2007 | 07:25 AM
jmackie's Avatar
jmackie
5th Gear
Default Differential Fluid Refill
Okay. I'm just now starting to get a little differential noise and minor grabbing/growling when making tight turns both forward and backward. What gear lube do I want to use? Additive? Hate the thought of having the melvins at the local Chevy dealership working on it. Took it in for rear link washer recall and got it back with a shock hanging unattached. I'll do it myself. Any horror stories?
Old Sep 9, 2007 | 09:16 AM
Jim2003's Avatar
Jim2003
I just did mine. I bought the original GM fluid and the little bottle of additive. The stuff lists for 29 a bottle and I get it for 22 a bottle. It takes 1.63 quarts according to the service manual.
Very easy to do. Jack up car, put on 4 jack stands. Take out drain plug, oops put catch pan under diff., take out fill plug, go drink coffee - 2 cups, come back, replace drain plug, put in fluid till it reaches the bottle of the fill hole, replace plug, ( put additive in after the first quart, not at the end).
Very easy to do. No problems. My mn6 with 35k had started the noises on hard sharp turns, after the fluid change it is totally quiet.
Old Sep 9, 2007 | 07:28 PM
Dave68's Avatar
Dave68
I did my diff and manual tranny fluid change not too long ago. I used Amsoil SVG 75W-90 synthetic gear lube for the diff and Amsoil Universal ATF fluid for the tranny. Both are excellent fluids and the ATF stuff does make shifting easier.
Old Sep 9, 2007 | 08:07 PM
rws.1's Avatar
rws.1
Mobil 1 or Royal purple 75W90 Gearoil PLUS 1 bottle of GM posi additive ( or aftermarket posi/limited slip substitutes)
Old Sep 10, 2007 | 12:41 PM
NigelTufnel's Avatar
NigelTufnel
Several people have drained their diff and then found out that their fill plug is stuck .
Therefore, before draining, I would at least loosen the fill plug.
I used Royal Purple 75W90 for limited slip diffs. No additive needed since it's already in there.
Old Sep 10, 2007 | 07:15 PM
WKMCD's Avatar
WKMCD
Royal Purple already has the additive in it.
Old Sep 10, 2007 | 07:17 PM
MattB's Avatar
MattB
I think red line also has the limited slip additive in it.
Old Sep 11, 2007 | 11:22 AM
Diceman9's Avatar
Diceman9
DAVE....
Do you have to use a additive with the amsoil?
Old Sep 13, 2007 | 10:53 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Originally Posted by Diceman9
DAVE....
The AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 comes with additive in it and use of additional friction modifier is not normally required for the C5. I've been using this fluid in my 02 Z06 on the track for years without additive and recently put it in my 06 CTS-V daily driver, again without additive. Neither diff has ever chattered.
That said, the C6 diff appears to perform differently and for my C6 customers I do recommend adding one bottle of AMSOIL Slip-Lock Differential Additive to stop the chatter they all seem to be getting with the stock fluid.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Sep 14, 2007 | 01:05 AM
Bluefire's Avatar
Bluefire
I used synth 75W-90 and the GM LSD additive. After you change the fluid do very slow figure-eights. I would do 3-4 forward and 3-4 backward. It will help work the fluid and additive into the synchro gears.
Old Sep 24, 2007 | 05:20 AM
jmackie's Avatar
jmackie
5th Gear
Default Thanks!
Thanks for the reply...
Old Sep 24, 2007 | 05:22 AM
jmackie's Avatar
jmackie
5th Gear
To Differential Fluid Refill
