Vinci Fan Controller
Old Sep 9, 2007 | 10:52 AM
Harris's Avatar
Harris
Default Vinci Fan Controller
Anyone have experience with the Vinci Fan Controller? I have a stock 03 Z06 and just want to turn the fans on sooner.
Old Sep 9, 2007 | 05:44 PM
vettenuts's Avatar
vettenuts
I have it, works really well. Both fans come on at the same time at low speed. Note the 04's use a different controller, I know you have an 03 but check with Vinci to make sure there weren't any late 03's that fall into the 04 criteria. There is also a screw on the unit so you can adjust the on temp, off temp is 7 degrees cooler.
