Nois eafter torque tube out ?
-Justin
-Justin
What made you replace the torque tube bushings and bearings and how much $$ did it run you?
They are: Front bearing: 12456210
Rear bearings: 12456221 (two required)
Also, the tube o-rings are showing as:
Front: 12456203
Rear: 12456220 (two required)
These numbers are shown for the later '01/'02 thru '04 shaft with the 63mm driveshaft diameter vs the early (55mm) shaft.
HTH
You can't buy individual parts from GM for the torque tube (at least I couldn't). You have to buy the whole driveshaft assembly.
I just rebult mine this spring
These are the bearing numbers on the original bearings I took out.
NSK 6007 DU need 1
NSK 6008 DU need 2
I used the following replacements:
SKF 6007 2RSJEM SINGLE ROW BALL BRGS 1 $25.64
SKF 6008 2RSJEM SINGLE ROW BALL BRGS 2 $29.33
I also replaced the couplers with:
2 FEBI BMW017526 26111227410 $45.45
They are the same couplers as in a '99 BMW 318ti
Mine is a Z06 or '01 and newer torque tube. The '97 thru '00 use the exact same bearings and slinger ring but a different coupler (10mm bolts instead of 12mm) It's also for a 318ti just an automatic.
I got my couplers from the BMW Parts Experts online. They had the best price. Make sure you get the FEBI or Lemforder brands.
You will also need to replace the slinger ring, GM part number 12456208 cost $4.42 from www.gmpartshouse.com.
NSK 6007 DU need 1
NSK 6008 DU need 2
Outstanding info! Well done!!!! Thank you!!
Bill
only GM would take a part for a 4 cylinder german car and slap it in a v8 set up.
GM Logic (oxymoron right there):
German designed to last for a sub 200hp car, so we'll put it on our 350hp v8 and so it'll have to be replaced or upgraded at every turn and we can steal a bunch of $$ from our customers.
O BTW we'll make it easy to access too, nothing like labor charges. Pohanka Chevy sits on the review board.
