MAF Sensor
Old Sep 9, 2007 | 06:51 PM
coanan's Avatar
coanan
Default 99 rewire to 01-04 MAF Sensor
Has anyone taken thier 97-00 MAF harness including the IAT wires and repinned them into the 01-04 maf connector? I need to use the larger MAF for my CAI.
Old Sep 9, 2007 | 10:25 PM
luch90's Avatar
luch90
you can buy a direct fit connecter from caspers electronics. plugs into your old iat and maf connecters to integrate them with the 85mm style.
Old Sep 9, 2007 | 10:46 PM
coanan's Avatar
coanan
Thanks for the info. Checked the site and found it, $30.00. Was hoping for the cheaper route by rewiring a plug. If all else fails I'll be buying one. Steve
Old Sep 10, 2007 | 02:01 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Hello---You'll have to re-calibrate you MAF tables when installing the newer style bigger MAF into cars with the earlier version--I tried this mod on my 98 and the fueling was -20% off--dead rich-finally threw codes--would barely idle and ran horribly---I tried adjusting the MAF table--but it is a huge job getting it perfect and after 2-3 days i just gave up and put the stock one back in--with screen---I learned that the 3.5 " MAF is good for 500 HP so really no reason for me to mess with it--only minimal HP gains if you get the table perfect anyway---i would try another way to connect your CAI---JMO---
Old Sep 10, 2007 | 08:37 PM
coanan's Avatar
coanan
good to know, thanks
Old Sep 13, 2007 | 06:27 PM
coanan's Avatar
coanan
Anyone else do this?
Old Sep 13, 2007 | 08:14 PM
YOULLUZ's Avatar
YOULLUZ
Can someone send me the link to where on the caspers site the connector is listed?
I looked under thier Corvette page and didn't see it listed.. I could be blind though..
Old Sep 13, 2007 | 08:50 PM
coanan's Avatar
coanan
https://www.casperselectronics.com/M...Category_Code=
Old Sep 13, 2007 | 08:53 PM
YOULLUZ's Avatar
YOULLUZ
Thanks..
I'm not sure why it's under LT1 products....
To MAF Sensor
