Tires
Old Sep 10, 2007 | 09:48 AM
weinerschizel's Avatar
weinerschizel
Default Tires
I'm looking at buying a 99 FRC. However, it needs new tires. What does a set of 4 tires typically run for the following on a FRC vette:
Oh yeah and it has the factory rims...
Lowest cost:
Middle grade tire:
High end tire:
I'm looking to drive on the street. Nothing fancy.
Thanks.
Old Sep 10, 2007 | 09:57 AM
Dave68's Avatar
Dave68
Low end: Avons (made in Ohio)
Highest end: Goodyear GSD3s (also made here in the USA)
Check www.tirerack.com for prices.
Old Sep 10, 2007 | 10:01 AM
jovette's Avatar
jovette
$500 for non-run flats, up to $1,400 for Goodyear Run-Flat replacements.
Old Sep 10, 2007 | 10:29 AM
rws.1's Avatar
rws.1
$500-$1000 for non run flats depending on what performance you want.
with a '99 you might need new tire pressure sensors ~$300
Old Sep 10, 2007 | 11:30 AM
Bugaboo's Avatar
Bugaboo
I'd stick with the runflats made in the good ole USA
To Tires
