Security Light on Dash
Old Sep 10, 2007 | 10:28 AM
DJKP's Avatar
DJKP
3rd Gear
Default Security Light on Dash
Having trouble with the security light on the dash. When first starting the car, sometimes it will not go out, but once I turn the key back and start a second time, it then goes out. Anyone have the answer to this? It DOES NOT come on while driving.
Sorry, it's a 98 vert.
Old Sep 10, 2007 | 11:11 AM
jirasvet's Avatar
jirasvet
Old Sep 10, 2007 | 12:12 PM
DJKP's Avatar
DJKP
3rd Gear
Originally Posted by jirasvet
You have some info?
Old Sep 10, 2007 | 12:16 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The key cylinder contacts for the chip are wearing out, assuming its the same as the '99's.
Old Sep 10, 2007 | 01:33 PM
jirasvet's Avatar
jirasvet
Originally Posted by DJKP
You have some info?
Well I do not know how correct it is. I watching to see what others posted, and I have had experience with other GM models just not with the c-5 yet.
There are several variables on a c-5 for the security light. As for the Pass Key it has been used on several GM models and have had similar security light issues. The key pellet in your key like stated could be damaged, or dirty and the BCM did not recognize the value stored in memory. Another problem could also be a bad or contaminated sensor in the key cylinder lock housing.Possibly a loose connection on the sensor.
I know on other systems if the pass key value is not recognized, but within a set value in the PCM it will illuminate the security light but still allow vehicle to start.
(If you get a new key or it gets worn)Other models are also able to do a relearn by watching the security light. When key is inserted and turn to run position If the security light flashes four times and stay on then you have to wait ten minutes and it will relearn the value and the light will go out. Then you must turn off ignition restart and it will start with no light.
Check the Basics:Keys(worn or damaged),Battery Voltage also check for codes, there are sevral codes linked to the Security light
You may just need to do a relearn if the C-5 is the same as other GM models
To Security Light on Dash
