Wheel Offset Help Needed
Old Sep 11, 2007 | 10:04 PM
Roger@CCC's Avatar
Roger@CCC
Default Wheel Offset Help Needed
I am planning to install an LPE minitub kit in my 03 Anniversary convertible. I want to be able to mount 345/30ZR19 INVO's on 19x12 wheels, and keep them within the stock fender lines.
Can anyone tell me the correct offset to specify wnen ordering the wheels?
If it matters, I have Baer Eradispeed oversized rotors.
Thanks for your help.
Roger@CCC
Supporting Vendor
Old Sep 11, 2007 | 10:48 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
74-76mm ballpark to keep them from sticking out of the fender.
Inform your wheel maker about the big brakes. If you are looking at multi-pc wheels, creating the needed spoke clearance will likely reduce the outer lip size - brake clearance doesn't have much to do with offset unless you are talking one pc wheels.
