Vararam Intake Question???
Old Sep 13, 2007 | 03:29 PM
PerrinPhantomZ06's Avatar
PerrinPhantomZ06
Default Vararam Intake Question???
So if I decide to install a vararam intake on my z06 this would force me to remove the front brake cooling ducts? Does this bother anybody? Is there noticeable difference with and without the brake ducts in braking and temps? I am not a race car driver but plan to track the car occasionally as well as occasional freeway pulls..I like to know that my most important brakes are cool and stay that way...Any thoughts or ideas will help me form an opinion.
Thanks in advance
Zach
Old Sep 13, 2007 | 03:32 PM
PerrinPhantomZ06
Default Oops
Wait a second....The vararam is connected to the other ducts above the brake ducts isn't it. I think I may have overthought myself on this one.
Old Sep 13, 2007 | 03:59 PM
tabbruzz's Avatar
tabbruzz
Fog light surrounds, not the brakes.
Old Sep 13, 2007 | 06:01 PM
timemender's Avatar
timemender
True, it sucks air through the fog light cutouts, NOT the smaller brake cooling intakes.
Old Sep 13, 2007 | 07:34 PM
PerrinPhantomZ06
Default Any Good Reason
Would it be beneficial to add a bigger air bridge to this intake kit??Bigger Plastic Or carbon Fiber One??
Old Sep 14, 2007 | 12:31 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Not really.
Old Sep 14, 2007 | 10:25 AM
PerrinPhantomZ06
what about the vararam throttle body velocity stack??
Old Sep 14, 2007 | 12:00 PM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
Don't waste your money on $400 intakes when you can modify your existing one to have access to cold air. Just buy a $35 K&N filter.
http://forums.corvetteforum.com/show...26&postcount=2
I'm sure all the vararam nuts will show up and rant about .1 reductions in 1/4 mile times, blah blah blah. You can save your $300-$400 bucks towards mods that greatly improve performance. Don't waste your money on "smooth air" couplers or throttle body inserts either. People complain about the "corvette tax," but sadly most of that is self-inflicted.
Old Sep 14, 2007 | 01:03 PM
DefenderC5's Avatar
DefenderC5
Vararam intake is nice, but the velocity stack is better served as a paperweight. Save your money.
Old Sep 14, 2007 | 06:09 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
Velocity stack is a waste of $. Had it in my 93, and it did nothing except drain my cash. However, my Vararam did make a big difference in my 03, and it does NOT go where the brake ducts go, but where the fog lights are. You can try the zip-tie mod first, to see if that works for you ( do a search). If not, the Vararam is a great bang for the buck.
Old Sep 14, 2007 | 07:44 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Old Sep 14, 2007 | 10:52 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
I like the flip mod,.......looks great for the money!I very well may have tried that before I got the V-ram.
One thing that I have always thought about is that the v-ram does not share the air that is meant for the radiator.
As tempermental as the lsx engines are when it comes to heat,I like the fact the v-ram does not rob any cooling air from the radiator.
Nor does the radiator get a chance to warm the air at all going into the intake.
Callaway also incorporates said design,so I wonder if there is any testing data compiled as to this issue
It may be minimal,I never see ANY talk about it
I still like the V-ram,but the flip mod is definately a budget winner!
Old Sep 14, 2007 | 11:33 PM
skydive120's Avatar
skydive120
What exactly is the flip mod?
Got a link?
Old Sep 15, 2007 | 12:31 AM
PerrinPhantomZ06
This is what i had suspected, i have a k and n drop in, but wont alot of debree get shoved onto the front of the element??? anyone ever had problems with the zip tie mod??
Old Sep 15, 2007 | 12:51 AM
Cajundude's Avatar
Cajundude
Yea, VaraRam is really not worth it, I mean even though I personally tested it at the track it only got me the following:
Without VaraRam - 12.618 @ 110.43
With VaraRam - 12.173 @ 112.22 (best trap at 113.17)
That's quite a difference from a tenth as you mentioned. While I do sell the VaraRam, I'm not hear to sell it, I'm hear to defend the answer above. I'd be willing to listen to answers like that when that person has personally tested it at the track and provides fact, not speculation. There is no other track proven intake other than the VaraRam that I have seen. It is not just me, there are plenty of testimonials. VaraRam users don't have to rant cuz they know it works.
As far as the mod above, that is a great looking mod! Very well done.
Jason
Old Sep 15, 2007 | 12:52 AM
Cajundude's Avatar
Cajundude
...when someone tests back to back the $35 filter,then I'll listen and be on your side.
Old Sep 15, 2007 | 11:36 AM
VaraRam Industries's Avatar
VaraRam Industries
Supporting Vendor
St. Jude Donor '07-'11-'12
Jason
Thanks Jason!!!! We love you too!!!! and and
To Vararam Intake Question???
Old Sep 15, 2007 | 05:33 PM
JustLucky's Avatar
JustLucky
The VaraRam works and works well - best C5 air intake in my opinion.
Don't waste your money on the velocity stack - just get a ported and polished throttle body.
As far as the bigger air bridge - I say every little bit helps and the stock bridge seems restrictive to me...
Hope this helps!
Old Sep 15, 2007 | 11:05 PM
skydive120's Avatar
skydive120
Its a little off topic, but I hear the vararam has some serious quality issues?
Performance or quality....... Id rather pick up a few HP my self, but quality is very important.
Opinions?
Chris
Old Sep 17, 2007 | 10:23 AM
BowTieRocket's Avatar
BowTieRocket
Opinions?
Chris
I've got the current one, so can't speak to the original design. It isn't glitzy, but that's not what I was buying. It fits well enough that I had no problems installing, and the worst part was just figuring out how to remove the original, and the radiator flow shroud and all. First time I'd worked on the car at this level - taking off and replacing body components. I'm more comfortable with the engine - plugs, oil, the odd EBTCM.
It looks close enough to GM in quality and material that I've taken off the Vararam sticker (to make it not so obvious), and will try to get it past the Smog ***** in a month or two. If I find a shop that doesn't see a lot of Corvettes, I think it will slide past the visual inspection.
Overall, good product. Not over-done; I don't really think carbon fiber would improve things in this area, any more than chroming the air filter lid on the '60s muscle cars did. But wait! Chroming the lid on the Shelby did add 35 HP and take nearly 2 seconds off the quarter mile time (not...).
In the end, you go with what makes you happy. I like the Vararam. If you like the zip tie mod, peace be with you...
