should or shouldnt i replace the mass air flow sensor?please help
Im going to put the vararam intake on my stock 01 vette.Now,would it be wise to replace the stock air flow sensor when i do this or wont it make a differents.
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
Aftermarket MAFS are the single biggest wastes of $$$ if you are looking to mod. You will see ZERO gain and possibly have codes. It is a big and most good tuners will take it off and go back to stock if you have it tuned.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Not necessary! Leave it be!
BC
BC
St. Jude Donor '13-'14-'15
Yes--the stock MAF is good for 500 RWHP---getting an aftermarket MAF to work correctly takes hours of data logging and tuning--and it probably still will surge and buck --Not worth the trouble --even when tuned well--only 3-4 RWHP there anyway--
Stock MAF--screen and all !!!
Guest
Posts: n/a
Really?
But then, that's logic
If the factory throttle body is 90mm, and the factory MAS is 85mm, how could changing the throttle body to say, a Lingenfelter 100mm unit not be good? Seems from a logical perspective that more air passing through the MAS would mean more available air for the throttle body, and thus increase hp by having all that available air at any given time available to the motor.
As tblu92 points out, if you want to spend hours and hours re-calibrating the PCM for the new MAF ... then you may see a benefit and not get codes. But given that there are MUCH bigger gains to be gotten from other changes, very few people think an aftermarket MAF is worth the tiny gains for hours of pain.
Hey was it red??? Just kidding No gains here either.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
