Question on what is leaking...
The drip land right in the middle (left to righ) of the car and looks to be right in line with the middle of the rear wheels (maybe slightly forward then the middle of the rear wheels). Of course, I can't get under it to see what is leaking, but it appears to be directly in front of the axle. Would this be right where the u-joint is from the drive shaft as it comes back to the diff? Is this the "leaky butt" as stated in the weights and measures thread? Has anyone had something like this fixed and if so estimated $$$? I will try to take it to a shop on Saturday so they can take a look, but wondered if anyone would have a idea before I go.
Lots of posts on forum about this check these also
http://www.corvetteactioncenter.com/...over+Flange%29
http://www.corvetteactioncenter.com/...al+Replacement
Looking around $300 give or take
Leaky butt
Had trans on my 1500 mile '07 replaced. Leaked in a similar area to what you describe. They replaced the small "o" ring seal for the trans cooler line to the trans. Got home still leaked. They have now replaced the driver side transaxle seal today. Picked up the car 2 hours ago and so far no leak. Agree with jirasvet. He notes problem areas that are solid possabilities. My posts on both issues are below. Don't think you have much to worry about. Good luck!
Fran
Trans failure:
http://forums.corvetteforum.com/show....php?t=1763547
Trans leaks:
http://forums.corvetteforum.com/show....php?t=1810578
As a FYI, there are no U-joints in the C5 driveline.....the torque tube bolts solidly to the engine's bell housing, and runs to the transmission, which is bolted directly to the front of the rear differential. With independent rear suspension, there's no need to couple the driveline with U-joints. The differential is rigidly mounted to the rear carrier and doesn't move in relation to the car's frame. As for the leak, it sounds like it's either the differential side cover seal/axle seal, or it may also be the seal between the transmission and differential. Determine what the fluid is (smell, color, taste
)....if it's ATF, it's leaking between the tranny & diff. If it's differential fluid, it's the cover and/or axle seal.HTH
Mike
Mike - Thanks for the info. As for the smell, color, taste
I can't smell much of anything from the small dropping I get on the floor.
Color - looks to be black. Taste - not sure as my point of reference for the past 17 years is BMW and Harley Motorcycles.
From all of your posts/threads, I believe your all correct in what the leak is. I'll post here what the fix was once I get it done!Thanks of the help! It amazes me at how quickly you get some GREAT info / help / resolution on a question / problem you post on this board!
Do not forget the Bushings that are at the driveline inside the torque tube. They are similar to u-joints and have been known to fail and cause clunking noises similar to a u-joint
Asked if I can drive it, they said, yes, should be fine, it's not a very fast leak and it will be OK till we get it in next week.
