On two occasions, once last month and again today, I found about 2 tablespoons of very light colored oil under my 04 A4. If you are facing the rear of the car, the oil was approximately to the left of the rear diff. I could be off in my guess as to where the oil was since I moved the car and then saw it.
I jacked the car up and took a look, but could not find any oil residue. What really puzzles me is why the oil leak is intermittent? I drove the car last night, went out today to move it and saw the oil. Any Ideas/thoughts? The car has approximately 11.300 miles.
The C5/Z06 rear differentials are notorious for leaking. Check the side covers thoroughly. It could just be a hint of a future repair. Do a search, using keywords "differential leak" to find prior discussions, some with images. Here's just one of many I found... http://forums.corvetteforum.com/show...ferential+leak
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Thanks in advance.
The only clear looking fluid to the left of the diff would be brake fluid, but that would be easy to find out if it was leaking because you may have no brakes.
The most likely option is the side cover leaking on the diff. It is one of the most common leaks on these cars and almost all of the C5's on the road have had the seals replaced. I can not explain why it would be intermitant, but it sounds like that is it.
Here is a thought. It could be coming from a few places. Some say it could be coming from a leaking breather valve on trans or diff. Causing intermittent leak. If no residue is found around area one could rule this out. If it is light in color like you say it sounds like trans fluid. Loose trans cooler lines could be the cause.The other is that the trans could be leaking fluid where the trans and diff connect and it just takes time for it to leak out of where they are connected. Plenty of info on the forum on the rear oil leaks.
If it smells really nasty - it's diff oil. The only way to describe the smell - Rotten eggs.
I second that. The extreme pressure additives in GL-5 gear lube contain a lot of sulphur. When mine leaked I could smell it as soon as I walked into the garage.
Transfluid is red and feels thin like cooling oil when you rub it between your fingers.
rear diff fluid is very light amber-green and feels thick like honey if you rub it between your fingers...
Trans fluid is not as stinky as that.
The fluid I found is clear and does not smell bad at all. rws.1 best describes what I found. I'll take it to a local shop and have the rear diff checked out for leaks. Should be covered under warranty.
Thanks very much for all responses. I knew I could count on the CF folks to help me out.
