Drive by wire question
Old Sep 15, 2007 | 09:13 AM
skywalker01's Avatar
skywalker01
6th Gear
Default Drive by wire question
All -
I'm trying to understand the Drive by Wire setup and when going through the schematics I notice references for TP (Throttle Position?)Sensor #2. Are there (or could there be) multiple TP sensors on the engine?? I know of only the one on the throttle body. I'm sorry if this is a dumb question, but I'd really appreciate any assistance!
Thanks in advance!!
Old Sep 15, 2007 | 09:26 AM
widewheel's Avatar
widewheel
could be refering to the one on the accelerator pedal
Old Sep 15, 2007 | 09:50 AM
skywalker01
6th Gear
I originally thought that too, but the pedal is called out as APP (Accelerator Pedal Position). The signal wire actually goes to the
underhood electrical center. The wire in particular is pin 11 on the Throttle Actuator Control Module.
Thanks for your comment!!
Pat
Old Sep 15, 2007 | 10:38 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are two phases of the one TPS. If you measure one side of the switch the resisyance will be high going low and the other side will be low going high. Its a checks and balances circuit. If the resistances are not equal but opposite, it will force the PCM to go into reduced power.
Same goes for the Accelerator Pedal Position switch. Two phases.
BC
Old Sep 15, 2007 | 10:52 AM
skywalker01
6th Gear
Bill - thanks! That seems about right. But do you know why they send it to the dash (cruise control?) and not the PCM? Is this a 'redundancy' that one can do without?
Thanks again!
Pat Walker
Old Sep 15, 2007 | 11:09 AM
skywalker01
6th Gear
Bill/All -
So if I were just to disable DTC Codes P1220 and 1125, that would 'kill' that wire?
Thanks again
Pat
To Drive by wire question
