Headlights flicker when brakes applied
Old Sep 16, 2007 | 01:01 AM
02milleniumrag's Avatar
02milleniumrag
Default Headlights flicker when brakes applied
I noticed that when driving at night my headlights dim very slightly for a split sec.when i hit the brake pedal. I did it when i got it into the garage and my wife said she cant see it and that i am crazy. but it does do it . anybody else notice this??
Old Sep 16, 2007 | 01:40 AM
DeeGee's Avatar
DeeGee
First thing I'd check is that the battery leads are tight.
How's your battery? If its the original I'd be changing it anyway. The older AC Delcos leak and I wouldn't take the risk. You can have a load check done free at Autozone.
Old Sep 16, 2007 | 02:46 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
It may happen when you apply your brakes due to the extra load. If you raise or lower your windows does it happen then as well? The reason you probably notice it is because of the brake lights adding that little extra current draw.
Here are a couple of links that may help.
http://forums.corvetteforum.com/show...ing+headlights
Old Sep 16, 2007 | 08:58 AM
stevezfl's Avatar
stevezfl
I have a similar problem. It seems to be normal for the car as I've owned it for several years and hasn't caused any problems.
The head lights on my 98 momentarily dim then brighten again. Usually as the car is warming up. After it's warm I don't notice it anymore.
There is an associated electronic "whistle" noise as it happens. The whistle also happens in the day with out the head lights on.
At one time I removed the alternator and took it to the parts store to check it out. They said the voltage regulator capacitors took longer then normal to charge up (the whistle?) and that the alternator was no good. I ignored them and put it back in the car. The car runs fine, it just has that annoying dimming of the head lights.
The explanation in Bill Curlee's post leads me to think there's more to it but it's all just normal.
Any more electronic experts out there?
Old Sep 16, 2007 | 12:11 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Normal........
Old Sep 16, 2007 | 03:30 PM
Switchbarrel's Avatar
Switchbarrel
Default Headlights
Here's another one for ya'. There's a mountain pass between my house and work. Every night on my way home, when I crest the top of the hill and my car starts pointing downhill, my headlights blink/dim ever so slightly.
-Rick
Old Sep 16, 2007 | 09:17 PM
02milleniumrag
wish i could drive mine to work
Old Sep 16, 2007 | 09:42 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
Count me in, mine does the same thing
Old Sep 17, 2007 | 07:00 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by 02milleniumrag
wife said she cant see it and that i am crazy. :
My 2nd. wife always told me that and I still look for her in the obituaries now and then Slight dimming is pretty normal in my experience..........
Old Sep 17, 2007 | 11:29 AM
DefenderC5's Avatar
DefenderC5
Originally Posted by stevezfl
... After it's warm I don't notice it anymore.
There is an associated electronic "whistle" noise as it happens. The whistle also happens in the day with out the head lights on...
Sounds like the fuel pump to me. When the load changes, the pitch of the fuel pump whine changes also. If you want to see it yourself, just push both window up buttons for a moment while the window is already up, the change in the sound is obvious. The headlight dimming, fuel pump whine... it's all normal. Welcome to GM.
Old Sep 17, 2007 | 12:23 PM
Oldvetter's Avatar
Oldvetter
But do not tighten your battery leads over 11 ft-lbs. Overtightening them can cause them to leak and your computer is under your battery !
To Headlights flicker when brakes applied
