More 10 cent washer carnage
Old Sep 16, 2007 | 06:58 PM
ArKay99's Avatar
ArKay99
Default More 10 cent washer carnage
Started stripping the block today. Found a lot more pieces of the piston and the reason the cylinder wall cracked. Not pretty
You can see how the washer just crushed through side of the piston
The force of the washer crushing through split the skirt off and must have thrust the piston sideways into the wall.
The pieces of the skirt I pulled out of the bottom of the motor.
The good news is if I can find a shop that can resleeve the block for #7 near Bergen County NJ I should be able to rebuild it. Anyone know of a shop that can resleeve this for me?
Old Sep 16, 2007 | 07:05 PM
Mike04's Avatar
Mike04
Ouch!
Old Sep 16, 2007 | 09:47 PM
Bob CTS's Avatar
Bob CTS
That sucks and if you do find a shop to re-sleeve let us know how it goes. Good luck with the repair.
Old Sep 16, 2007 | 10:14 PM
thetaxman's Avatar
thetaxman
I'd buy a new block
Old Sep 16, 2007 | 11:03 PM
gonbad's Avatar
gonbad
If you are going to re-sleeve it. Then go big bore and do the whole block. You can find good used LS1/LS6 blocks for around $500. If you want to stay stock I would go that route.
Old Sep 17, 2007 | 12:14 AM
ArKay99's Avatar
ArKay99
I guess nobody saw the my last post regarding this motor, sorry about that. I have a 403 being built by Lingenfelter on the way. I want to put this motor back to stock so I can run it in my truck. If I can get it resleeved fairly cheaply and get a new piston all else is fine. Not going to build it for high power or rpm's.
To More 10 cent washer carnage
