automatic trans pan
Old Sep 16, 2007 | 11:40 PM
kenh's Avatar
kenh
Cruising
Default automatic trans pan
I have a leaky trans pan on my C5 automatic and suspect it may need a new pan. What is my best option, stock or aftermarket?
Old Sep 17, 2007 | 12:54 AM
thetaxman's Avatar
thetaxman
I'd bet it's just a gasket, not the pan.
If you have a hole in the pan, a stock one is fine.
Old Sep 17, 2007 | 01:47 AM
Bounty's Avatar
Bounty
He's right, it probably is just a gasket but if it's coming off anyway, you might want to look into a deep sump pan. Adds a few quarts for lower tranny temps and improved tranny longevity....
Old Sep 17, 2007 | 12:12 PM
Lone_sword's Avatar
Lone_sword
I'm looking into buying a deeper pan also. Can I buy any 4L60E pan or does it have to be corvette specific?
Old Sep 17, 2007 | 12:54 PM
OhioDave's Avatar
OhioDave
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
This may help, Full line of products for the 4L60E. The leak is probably a gasket problem. If you pull the pan to just change the gasket I would at least change the filter and clean the stock pan. Make sure you torque the bolts when you re-assemble. I believe it is 8ftlbs.
http://www.bmracing.com/index.php?id...subcat=&pid=39
Old Sep 21, 2007 | 08:18 PM
thetaxman's Avatar
thetaxman
nice, but the fill plug needs to be on the side, not the bottom.
How would you fill the tranny ?
Old Sep 22, 2007 | 01:31 AM
Bounty's Avatar
Bounty
Here is the one I was referring to with the side-mounted fill hole...
http://yourcovers.com/tp_8650-3.shtml
Depending on your model year (and if the pan bolts secure the shift cable) there may be some minor mods required.
Old Sep 22, 2007 | 03:02 AM
thetaxman's Avatar
thetaxman
that looks good.
the one problem with cast pans is that they don't dent, the crack like an egg is something hits it.
Old Sep 22, 2007 | 03:08 AM
Bounty's Avatar
Bounty
Originally Posted by thetaxman
that looks good.
Definitely not for lowered rides...
Old Sep 22, 2007 | 11:28 AM
thetaxman's Avatar
thetaxman
sometimes debris gets kicked up and there is nothing you can do even if you are not lowered
To automatic trans pan
