MAF cleaning
Old Sep 17, 2007 | 01:08 PM
skidmarc's Avatar
skidmarc
Default MAF cleaning
Guys,
Do you advise cleaning your MAF sensors? If so, what's the best product/method? I have heard q-tips to spray cleaners. My thoughts are that both would leave residue and should just replace it?? I found a local shop that carries CRC MAF cleaner and may try that.
Old Sep 17, 2007 | 01:09 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
CRC MAF cleaner
Old Sep 17, 2007 | 01:20 PM
mickey_7106's Avatar
mickey_7106
Originally Posted by Humanoid 2.0
CRC MAF cleaner
no Q-tips though.
Old Sep 17, 2007 | 02:08 PM
skidmarc's Avatar
skidmarc
Originally Posted by mickey_7106
no Q-tips though.
Did you guys notice a difference in performance?
Old Sep 17, 2007 | 02:54 PM
rws.1's Avatar
rws.1
CRC MAF cleaner... most autoparts stores...
Just spray it... don't touch the wires with anything... let it drip dry....
Old Sep 17, 2007 | 07:17 PM
mickey_7106
i got better mpg
Old Sep 18, 2007 | 02:00 AM
nighteu4ia's Avatar
nighteu4ia
crc maf is what u need. the solvent and the pressure from the spray will thoroughly clean your maf.
Old Sep 18, 2007 | 12:02 PM
bighank's Avatar
bighank
Default Brake cleaner and NO Q tips clean the TB too
Took my MAF out and sprayed liberally with brake cleaner then let it dry in the hot summer sun. Just want to remove the crud on the wires and surrounding area. I also cleaned my Throttle Body with some TB/Carb cleaner. If the MAF is dirty so is the TB. BIGHANK
Old Sep 18, 2007 | 06:47 PM
TAZZVETTE's Avatar
TAZZVETTE
It worked for me
Old Sep 18, 2007 | 07:14 PM
Humanoid 2.0
Brake cleaner is too harsh, that is why they make MAF cleaner.
Old Sep 18, 2007 | 08:40 PM
2001PewterCoupe's Avatar
2001PewterCoupe
I used Radio Shack electronics cleaner in the brush spray can. Took the MAF apart and cleaned it really good. Tried with some cotton swabs but noticed that they left some threads of cotton sticking. Cleaned it really good though, it was dirty.
To MAF cleaning
