advice would be nice
Old Sep 17, 2007 | 08:59 PM
goody03's Avatar
goody03
Default advice would be nice
my first time to the track i went easy on the car and i was launching out of the hole at 3k rpm-ish, and the car was doing fine but if i left at 4k rpms i would wheel hop. my biggest fear is breaking something.. i do like to leave at higher rpms...the car is stock at the moment..what do you suggest i do to straighten things???
thanks
bill
Old Sep 17, 2007 | 09:48 PM
NightmareZ06's Avatar
NightmareZ06
thanks
bill
If your cutting good 60' times at 3k, then stay there. Thats where i launched my stocker for a 1.9 60' and a 12.3 @115.9. Also, are you slipping the clutch at that 4k launch? What tires and tire pressure are you running? DR's are also a possiblity if you like to leave at high R's. I leave at 5k on mine.
Old Sep 17, 2007 | 11:42 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Wheel hop is a big no-no--I would deff. back off the launch RPM until you can figure out how to get rid of it--however if you are getting good 60' times--them 3000 is fine anyway--Oh--and wheel hop will usually break the output shafts on the differential--I believe the left side is the one that always breaks--you can buy a stonger one from several vendors on the forum--they are about $3-400 plus the install-
Old Sep 18, 2007 | 12:12 AM
goody03's Avatar
goody03
my 60's are not the best. my best is 2.08 and most of them are 2.1 2.2. but i have only gone once.. i do need DRs. I spin like a bi no mater what i do, so the R's have to stay lower.
How can i make my rearend stronger??
What do you guys have done to your rearends to leave at high R's??
thanks
bill
Old Sep 18, 2007 | 10:11 AM
goody03's Avatar
goody03
someone
Old Sep 18, 2007 | 11:07 AM
02gt350's Avatar
02gt350
if you feel wheel hop, get out of it fast.
buy a DTE brace for 350 bucks.
Old Sep 18, 2007 | 11:54 AM
AlwaysInBoost's Avatar
AlwaysInBoost
your 60's aren't bad at all for your first time. if you get wheel hop try lowering your tire pressure and see if that helps. With radial tires there is only so low you can go until they start to cup on you. You can also try to slip the clutch a touch longer or don't give it as much gas out of the hole so the tires aren't fighting for traction so much.
IMO, I would stick with the stock tires @ your power level and learn to maximize traction with the power you currently have before switching to DRs.
Old Sep 18, 2007 | 08:21 PM
NightmareZ06
wheel hop just comes with these cars. I have wheel hop on the street but never at the track. Think about why your having it and then go from there. The tires are on the verge of traction and breaking loose. Either rase the tire pressure and spin a little or lower the pressure and try slipping the clitch a little more untill your moving enough that the tires will hook. Just try new things. Like said before, wheel hop is what breaks shafts, amungst other thing. I launching at 5k on DR's and my rear and IRS are all stock. New half shafts are coming though.
Old Sep 18, 2007 | 09:01 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
thanks
bill
You definitely want to avoid wheel hop at all costs. That how you destroy your driveline. I would definitely look into a DTE brace.
Also, do a search on a guy named "Ranger". He is a very good drag racer and posts a lot of good info.
Old Sep 18, 2007 | 10:40 PM
goody03's Avatar
goody03
thanks for all your advice. i am not new to the irs and drag racing and i would think I'm OK at it but i need to know what to do to the rear end.
Old Sep 19, 2007 | 07:55 AM
Independent1
St. Jude Donor '08
^^ The reason I suggested looking up Ranger is that he has been very successful drag racing stock corvettes. I figure if you want to keep your rear in tact do what he does cause he must be doing something right!
Never hurts to ask for advice from people with experience and from what I have seen Ranger is very willing to share and help his fellow vetters.
I think that is why I love this forum so much!!!
Old Sep 19, 2007 | 11:03 PM
goody03's Avatar
goody03
i will read this and see if it helps. thanks for the advice but i do think i need to buy a good set of Dr's
bill
To advice would be nice
