Intake Manifold upgrade and advice.
I have been looking at new Manifolds and throttle bodies but have run into some questions.
1) I read (or someone told me) that some of the 2001's actually have either the LS6 block or manifolds in them...is this true, and if so, how do I find out?
2) I know an LS6 mani will basically bolt onto my LS1, but what about an LS2? And if so, which one would be the best to go with?
3) With changing out the mani, will I need to change anything else out with it? Injectors, Fuel Rails (besides just the normal gaskets and such)?
4) I was going to have the car retuned after the header/exhaust install. Would I need to do it again after I installed the mani and throttle body, or can it wait until I do a pulley, cam switch?
The LS2 intake is a downgrade to the LS6 intake.
The only thing youll need to change if you dont have an LS6 intake now (1997-2000 Vette) is teh coolant lines under the manifold, you can either change them to the LS6 style or grind some fins of the bottom of the new intake.
