Getting ready to plunk down a grand on a new Z06 rearend.
I did the search thing and I'm 99.9% sure that this part will bolt on the back of an A4 trans------but I just wanted to get a definite "for sure" from the forum.
yes it will, but why use a stock Z06 rear. practically the same as a coupe or any other. if you are spending that much, why dont you get one from RPM for a little more?
The Z06 rear will work perfect. Unless you are building a race car, I wouldn't see the need for a built rear end by RPM or DTE. I would save the money to spend on something else.
Thanks for the information. I'll definitly look into RPM.
i meant DTE, but same thing.
to teh post above. my buddy just shattered his rear, and he was stock except for headers. shiit happens, so when yoru in there, make sure it dosnt and do it right the first time. my my opinion. these cars rear ends are glass jaws
See it as an investment. A DTE rear will last a lot longer and if you do future mods you'll already have a bulletproof rearend to go with it. When you get it, turn your traction control off!! Have fun
if you're not a racer.
don't forget to transfer over the "seal plate"... as the new carrier will not come with one.
The DTE stage 1 rear diff cost $1799 which is close to double a new Z06 rear diff. The weak link of the rear diffs from what I have read is actually the cases. They do not fair well if the car wheel hops at all. Now a DTE rear diff brace will help to solve the stress put on the case and would be a good precaution if the car was going to be drag raced or even driven hard on a regular basis.
Our Stage 1 C5 IRS Differential as an exchange is $1299, not $1799.
Best Regards,
Phil
Sorry for the misquote. I sold you guys my old 2.73 rear diff. It was a pleasure doing business with you. At that little difference in price from a new Z06 rear would have to say it would probably be better to go with a DTE rear.
