ebrake light
Old Sep 18, 2007 | 11:49 AM
11sec_C5Z51's Avatar
11sec_C5Z51
Default ebrake light
When I let my ebrake down, the ebrake light stays illuminated on the instrument cluster. What is causing this light to stay on?
Old Sep 18, 2007 | 11:56 AM
CODE4LS1's Avatar
CODE4LS1
It could be either a stuck switch or maybe low brake fluid in your master cylinder.
Old Sep 18, 2007 | 11:57 AM
11sec_C5Z51
where's the switch?
Old Sep 18, 2007 | 01:46 PM
BlackZ06's Avatar
BlackZ06
First thing to check is the fluid level in the brake reservoir. If it is OK, the next thing to do is check for any DTC that are related to the brake system. There are some DTC that can set for problems with brake pressure being high/low, etc. that will set the BRAKE warning light. Until the problem that set the DTC is cleared, that light will glow at you no matter what position the e-brake handle is in.
To ebrake light
