zip-tie mod
Old Sep 19, 2007 | 10:22 AM
RespondsWithGif's Avatar
RespondsWithGif
Default zip-tie mod
I have been reading about the zip-tie mod but I was wondering if the car sounded different after it, like is there an intake resonance afterwards.
Old Sep 19, 2007 | 10:46 AM
comecorrect's Avatar
comecorrect
I would modify the opening or do the flip top mod. Good luck!
MIKE
Old Sep 19, 2007 | 11:41 AM
RespondsWithGif
That looks interesting. Will that sound different?
Old Sep 19, 2007 | 11:49 AM
SKF engineer's Avatar
SKF engineer
I had the zip tie mod for a little while (I used large rubber bands)and I did not notice any real change in noise, I was actually hoping for a little more. Now I have something close to what "comecorrect" is talking about, since the zip tie mod does not use the air lid I found the intake wanted to move around a little so I prefer changing the air lid to meet my needs but keeping it to control the motion of the intake.
Long story short no real change in noise, if anything a slight increase at WOT.
Old Sep 19, 2007 | 02:57 PM
Chevy Guy's Avatar
Chevy Guy
You should hear a lot more noise, it is also way overkill, it wont contribute anything to your bottom line.
Old Sep 19, 2007 | 03:18 PM
Oldvetter's Avatar
Oldvetter
You did not list your car's year in your profile. Hard to help you without knowing info. Early year 1997-1999 (maybe 2000) C5's have terrible air filter tops, they breath thru 3/4 inch "straws". I put on a 2002 Z06 air filter top, well worth it.
Later year C5's have a better system, including a small slot on the front of the top (see bottom picture above).
Old Sep 19, 2007 | 03:50 PM
RespondsWithGif
I'm not looking for a lot of power out of it...I just went from a mustang to a corvette (90hp difference) so that is enough for now. I just want a little more noise until I get a real intake and exhaust.
Old Sep 19, 2007 | 05:32 PM
c5chines's Avatar
c5chines
I did the mod on my 97. I have to disagree as I noticed a bit more noise and a bit more power. Keep in mind,I have a 97 and they had a very restricted lid.
Old Sep 19, 2007 | 05:57 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
You may want to do a hood seal now. If water is sucked into the intake, Bye Bye. If I did a mod it would be the swiss cheese mod, not the zip tie. To much can go wrong with the zip tie.
Old Sep 19, 2007 | 07:44 PM
Chevy Guy's Avatar
Chevy Guy
This is a "Placebo Mod". Unless you have real heavy mods like heads/large cam, there is no restriction with the factory units, they flow pretty well.
Old Sep 19, 2007 | 08:49 PM
RespondsWithGif
Where did you get that weather stripping to do that?
Old Sep 19, 2007 | 08:50 PM
RespondsWithGif
I did the zip-tie today after I got off work. It is a little louder but I cant tell any difference in power. Mine is an 01 by the way.
Old Sep 20, 2007 | 09:27 AM
screw991le's Avatar
screw991le
Autozone $14. Bulb type weather stripping. It has a stick and peal backing. Just clean off the area with rubbing alcohol, measure the length and stick it on.
Not only does it stop water from coming in, it keeps the engine bay cleaner. The C6s have them from the factory, so that alone should tell you something.
It comes in a bag, enough for 2 cars. It is the same seal that the Corvette taxers get $40. for one.
Old Sep 20, 2007 | 10:38 AM
David426's Avatar
David426
8 rwhp is what I got from the dyno after the zip tie mod.. The factory air box is very very restrictive.. The flip tie mod is worth another additional 5-7 rwhp also.. Well worth the effort
Old Sep 20, 2007 | 11:17 AM
screw991le's Avatar
screw991le
I have seen dynos change 15 RWHP in just a few pulls. It is not worth the zip-tie coming off and sucking dirt into the engine. Also when it rains the water will get sucked into the crack at the hood.
Get a Z06 cover if you are looking to let in more air.
Old Sep 20, 2007 | 03:11 PM
BlackMagicC5's Avatar
BlackMagicC5
I never understood the point in doing the "zip tie mod". If you want more hp, just buy a real intake. Your driving a corvette, not a civic, do it right.
Old Sep 21, 2007 | 02:52 PM
c5chines's Avatar
c5chines
If there was no problem with the earlier lids,why did they change to a less restrictive one on later models.I can assure you I DID THE ZIP TIE MOD RIGHT.IT GAVE ME A BIT MORE NOISE AND A BIT MORE POWER!!! For free.Now that I added my $365 Hooker cat back, I'm a pretty happy guy.Thrifty isn't bad. If all Vette owners had the "pay through the nose,or it's not right" attitude, the dealers would charge $300 for an oil change.Oh wait, they already do.
To zip-tie mod
Old Sep 21, 2007 | 06:08 PM
robert123's Avatar
robert123
On my 97 , I noticed more power but no sound difference. Maybe it was because my catback covered up any noise diffence there may have been.
Old Sep 21, 2007 | 08:16 PM
KCJeff's Avatar
KCJeff
I decided against the flip tie/zip tie mod. Just installed a Blackwing. Like someone else mentioned, I don't think there is much of a difference until you are pushing 400hp. The air intake demands just aren't that high with a stock motor. Still, I can tell you that my engine absolutely ROARS to life now at w.o.t. (since installing the Blackwing). Very slight sotp difference, but probably nothing measureable. Exhaust is on it's way. Probably wont realize any significant benefit until headers are installed.
I made the change because of advice I received from my cousin (a career mechanic who works on LS1 motors). More air-in + less restrictive exhaust = better throttle response throughout the rpm range (probably will not result in substantial hp increase). Made sense to me.
Old Sep 22, 2007 | 03:14 PM
Rendell's Avatar
Rendell
Can someone post the dlip tie mod instructions, all the links i have found while searching are dead now.
