#*#* CD changer install
Old Sep 19, 2007 | 04:45 PM
ToplessSpiral's Avatar
ToplessSpiral
Default #*#* CD changer install
Need help with 12 disc changer install on '03. Can't put in bolts to hold changer. Please Help
Old Sep 19, 2007 | 06:07 PM
Mike Mercury's Avatar
Mike Mercury
http://www.corvetteforum.net/c5/unxp...s/changer2.jpg
Old Sep 19, 2007 | 06:08 PM
hotwheels57's Avatar
hotwheels57
CF member Patches did a detailed write up not long ago about installing the changer. He used a good method to attach the bolts for the brackets.
You might PM him or search for that discussion.
Old Sep 19, 2007 | 06:10 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Did you get the plate that is suppose to glue to the body? The plate has 4 bolts that are built on to the changer's plate. The plate attaches by adhesive to the body. The the brackets bolt down to the built in bolts.
But you can make your own, by gluing an MDF panel to the body and screwing the changer brackets to the MDF.
Liquid nail if you never want it to come off again or silicone if you do.
Old Sep 19, 2007 | 06:31 PM
ToplessSpiral
No plate w/ changer any other suggestions Thanks for other suggestions
Old Sep 19, 2007 | 07:08 PM
One Nut's Avatar
One Nut
I put my pioneer in the smuglers box on the right side
Old Sep 19, 2007 | 08:08 PM
hotwheels57
Contact Gene at GMPARTSHOUSE...I think he has the installation kit that you need for the install. It should include everything you need except the harness.
Since GM recommended the brackets be epoxied to the trunk compartment, there probably are not many good used brackets available. It would be fairly simple to make one up out of mild steel or aluminum though. I seem to recall that's what Patches did in his write up.
Old Sep 19, 2007 | 10:42 PM
94legaleagle's Avatar
94legaleagle
Originally Posted by Mike Mercury
What bracket are they talking about that you use for the template for drilling the holes?
I've got the CD changer and the "L" brackets, and I've got the 2 things that each have 2 bolts on them which are supposed to be riveted / glued to the rear tub wall
But the bracket part confuses me - is the bracket SOLELY for measuring purposes, or is it left in place for stregnth?
Old Sep 19, 2007 | 10:49 PM
94legaleagle
Linky to Patches write up - LOOKS good Patches!!
http://forums.corvetteforum.com/show....php?t=1740665
To #*#* CD changer install
