Code problems Help!
Not sure of the 58 but SDM is sensing and diagnostic module related to the B0022 or SIR system
inflatable restraint steering wheel module.inflatable restraint steering wheel module
inflatable restraint steering wheel module coil
steering wheel module high and low circuits
SDM sensing and diagnostic module.
Can't tell you how to fix it,do your basic Clear codes, disconnect battery for a few, check of fuse #16 under passenger kick panel, but all these stated above components and there connection/connectors need to be checked according to the book .The steering wheel module coil,inflatable restraint steering wheel module connectors are behind the panel under the steering wheel column maybe it got knocked around when column lock bypass was installed. The SDM is located behind the A/C controls.
Sounds like one for the dealer
