strange vibration?
Old Sep 21, 2007 | 02:09 PM
jbauch357's Avatar
jbauch357
Default strange vibration?
trying this in the tech section now cause it got lost in all the "bling" posts over in general...
When I come out of a corner hard, as in push through a corner and then lay down to full throttle exiting I get a strange vibration from the rear end. As long as I hold the throttle I will keep getting the vibration, but if I lift for a second then get back on the throttle things will be smooth again. Far as I can tell the vibration frequency increases with speed. I also never have issues when going full throttle in a straight line.
Could this be a differential fluid issue, or possibly clutch packs slipping? I don't see any indications that TCS or AH are kicking in when I feel this. I possibly added too much friction modifier last time I swapped the fluid, so recently I drained out a quart and replaced it with straight fluid - that seemed to help the issue (or it could be in my head) but it's still not gone.
Any ideas???
Old Sep 23, 2007 | 06:42 PM
jbauch357's Avatar
jbauch357
TTT
