Shifter change
Old Sep 22, 2007 | 10:27 AM
KCJeff's Avatar
KCJeff
Default Shifter change
*&$% Demon key wont come out of my stock
c5 ****. broke chunks off on both sides trying to pry it out. cant get vice grips to stay on. suggestions? I'm sitting in the car, looking at my
dremel right now!
Thanks,
Jeff
Old Sep 22, 2007 | 10:45 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Jeff
Drill a small hole into the top of the key and screw in a sheet metal screw. Then try to pull the key out with the screw. Make sure that the screw is not too fat, as that will cause the key to split.
BC
Old Sep 22, 2007 | 10:49 AM
4SFED Z's Avatar
4SFED Z
May help: http://www.vetteessentials.com/instr...t_install.html
Old Sep 22, 2007 | 11:11 AM
KCJeff's Avatar
KCJeff
You're the MAN, Bill. Worked like a charm. All done cursing now!
Thanks!
Jeff
Originally Posted by Bill Curlee
Jeff
BC
Old Sep 22, 2007 | 12:11 PM
LoneStarFRC's Avatar
LoneStarFRC
Thanks!
Jeff
WELCOME.......to the demon key club!
Old Sep 22, 2007 | 12:44 PM
KCJeff's Avatar
KCJeff
I may qualify for lifetime membership. You should see what I did to that little bas&%$d! It is unrecognizable. Once it was out, the shifter swap was cake.
Old Sep 22, 2007 | 10:34 PM
TAZZVETTE's Avatar
TAZZVETTE
Originally Posted by triche
Thanks for the info, very good illustrations
To Shifter change
