Help with a few codes, please...
Old Nov 12, 2001 | 09:55 AM
ScreaminDemon's Avatar
ScreaminDemon
Default Help with a few codes, please...
I just installed 3:73's and I know one of these has to do with it since my check engine light comes during certain shifts. I've been keying in smaller tire sizes into my HPPIII to try to get my speedo close but it's not working. (I know, I need to get loaded) Anyway, I can't find a few of these codes on my lists, I have a 99' auto. I'm also having trouble with the drivers side door keypad(AGAIN). Here's the codes, I would appreciate any help:
10 PCM P 1870 H C
BORFA C 2105 H This is right front TPM sensor malfunction. What does TPM stand for?
I hate all these sensors! :cuss :cuss
Old Nov 12, 2001 | 11:44 AM
CarlB's Avatar
CarlB
Default Re: Help with a few codes, please... (ScreaminDemon)
try: http://www.corvetteplanet.com/search.cfm
TPM=Tire Pressure Monitor
[Modified by CarlB, 8:22 AM 11/12/2001]
Old Nov 12, 2001 | 08:00 PM
c5wrench_2001's Avatar
c5wrench_2001
p1870 is a common occurance when changing gears on an automatic tranmission. You change the pulses per mile, therefore, the PCM thinks that the tranmission converter clutch is slipping, and defaults to high line pressure.
You will need to reprogram your PCM for this mod.
c5wrench
Old Nov 12, 2001 | 08:54 PM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
You can find codes here also:
http://www.corvetteforum.cc/techtips...D=26&TopicID=1
To Help with a few codes, please...
