Check Engine light - Codes?
Old Sep 25, 2007 | 08:28 PM
BCC5's Avatar
BCC5
Default Check Engine light - Codes?
On my 1999 C5 coupe, out-of-the-blue, the check engine light came on. Anybody know the method to check the code(s)?
Old Sep 25, 2007 | 10:08 PM
Plasticfan's Avatar
Plasticfan
Try this: https://www.corvetteforum.com/techti...D=26&TopicID=1
HTH
Old Sep 26, 2007 | 12:04 AM
BCC5's Avatar
BCC5
thanks...I will run the codes and see what's up.
Old Sep 26, 2007 | 07:53 AM
rws.1's Avatar
rws.1
post what you find...
someone here will have experienced the same codes before and likley have detailed DIY instructions for you.
Old Sep 28, 2007 | 10:45 AM
BCC5's Avatar
BCC5
Default I ran the diagnostic....
With the instructions that I rec'd on this forum I ran the diagnostics and came up with a few "codes" and reset them. Granted that did not fix anything but it did shut off my check engine light. I am at least smart enough to realize that if the light reappears then I will have the car professionally checked and repaired.
I really believe that the check engine light came on in conjunction with my "active handling" seemingly "warming up" by itself! That is another little quirk that happens once in awhile after breaking loose a little on gravel or wet surface.
But again, thanks for sending the instructions to go through the diagnostics. This time I printed them and filed them.
To Check Engine light - Codes?
