Please help with codes
Old Sep 26, 2007 | 11:29 PM
Itallian33's Avatar
Itallian33
Default Please help with codes
Ok i checked my codes tonight after doing some maintance work. take a look
A0-LDCM B2282H
A0-LDCM B2284H left Door Control Module
A0-LDCM U1064H
A1-RDCM B2283H
A1-RDCM B2285H Right Door Control Module
A1-RDCM U1064H
A6-SCM B0851H I dont know??
Ok, so i know that i need to pull the connectors out of the doors and check the wires going to the Door control modules on each side.
I don't know what the last code is for. The Vette doctors website suggestd it was "Lost communication with XXX?" What does that mean
Thanks for the help guys
jason
Old Sep 27, 2007 | 08:52 AM
Itallian33's Avatar
Itallian33
Ttt
Old Sep 27, 2007 | 09:04 AM
Neil Baker's Avatar
Neil Baker
Default your codes
I don't think I would worry about H (history) codes. If you don't see any C (current) codes. Did you have your battery disconnected? I would reset your codes via the DIC ( driver information center). After you reset the codes, run the car for a while then recheck the codes.
Of course, I'm just guessing....I'm far from a wrench.
Old Sep 27, 2007 | 09:18 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
A0-LDCM B2282H
A0-LDCM U1064H
A1-RDCM B2283H
A1-RDCM U1064H
jason
Loss of communications means the data port lost contact with either the BCM or PCM. It's like a computer network and when you loose a signal you get error report. No big deal, could have been caused by disconnecting battery or removing component to work on it.
If you install after market radio or seats you will have a permannet loss of comunnication as you will have removed the control module.
If I were you I would clear codes and then see if any come back, if not you're set.
Old Sep 27, 2007 | 01:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Clear ALL the codes and see if any of the ones you have now, reoccur.
BC
Old Sep 27, 2007 | 09:36 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
BC
Several "loss of comm" codes. Reset and see what you get.
Old Sep 29, 2007 | 11:03 AM
Itallian33's Avatar
Itallian33
Ok so i checked the codes after clearing them and my car shows no codes. I feel kinda stupid but i never cleared them after i replaced the ground packs with eyelets and cleaned everything. So for the first time that i have owned my car it isn't throwing codes
I didn't drive it much, but hopefully it stays this way
Jason
To Please help with codes
