Lowering the C5...
Old Nov 12, 2001 | 02:39 PM
ghostmech's Avatar
ghostmech
Default Lowering the C5...
I just bought my 99 C5 HT and would like to lower it some. I lowered my 93 Formula with different springs (Eibach) Is that how one would have to lower the C5? I'm not familar with the C5's 'tricks of the trade' so any help is appreciated.
Old Nov 12, 2001 | 02:44 PM
c5vetteman's Avatar
c5vetteman
Default Re: Lowering the C5... (ghostmech)
Check out tech tips in the forum. One way is to crank down on the bolts in the front and cut the bushings in the rear.
:cheers:
Old Nov 12, 2001 | 03:07 PM
COOL Z06's Avatar
COOL Z06
Yup, check the Tech Tips!! :cheers:
Old Nov 12, 2001 | 04:46 PM
Mike99C5HT's Avatar
Mike99C5HT
Default Re: Lowering the C5... (COOL COUPE)
Also do a search on lowering across all forums and you'll find countless posts on the subject. You can expect a drop of about 3/4" to 1" by just turning the bolts...no cutting required.
Old Nov 12, 2001 | 04:59 PM
c5vetteman's Avatar
c5vetteman
Default Re: Lowering the C5... (Mike99C5HT)
Do you need a new alignment when you just turn the bolts?
Old Nov 12, 2001 | 08:47 PM
PHAT CHANCE's Avatar
PHAT CHANCE
Default Re: Lowering the C5... (c5vetteman)
I've never got one since I lowered mine, but it's a good idea. I'm getting new tires in a couple weeks so I'm just going to do it then. If you switch to non-runflats, it's a good idea to have the alignment changed too. I'm planning to use the ZO6 camber and toe numbers when I put the new treads on. We'll see how that feels. *fingers crossed*
-Chance.
To Lowering the C5...
