Easy brake question
Old Sep 27, 2007 | 03:49 PM
SKF engineer's Avatar
SKF engineer
Default Easy brake question
I pulled the rear rotors off the other day to inspect the E-brake and I have a question regarding the little tin (or pick your favorite cheap metal) sheet metal retainers on two of the five lug nut studs. These things shred your fingers a little during removal and I personally would rather do without them. My simple brake question is.... Are these pieces just used during assembly in Bowling Green and then serve no purpose for the future or is there a reason to re-install them after removing the rotors.
Thanks for the help.
Old Sep 27, 2007 | 04:11 PM
jirasvet's Avatar
jirasvet
Technically you do not need them I do not reuse them. However they help providing the purpose of helping hold the rotor flush to the hub and aid in proper wheel install. (blah,blah,blah)
Its all up to you
Old Sep 27, 2007 | 04:16 PM
bighank's Avatar
bighank
Default Are used during production to keep the hubs ON
Throw em OUT
Old Sep 27, 2007 | 04:44 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by bighank
Throw em OUT
Chunk'em. Assembly line usage only. Kinda like the rubber band under the console/radio trim panel. Assembly line usage.
BTW, on the rubber band; if you wind it really tight you will get much faster acceleration. You've been warned.
Old Sep 27, 2007 | 06:22 PM
Last C5's Avatar
Last C5
Throw em OUT
Especially if your mounting CCW or any other after market wheels without an inset for the little devils.
Old Sep 27, 2007 | 06:39 PM
johninar's Avatar
johninar
DING DING DING..... we have a winner. It's just to keep things snug during assembly. Rip those suckers off and don't look back.
Old Sep 28, 2007 | 09:07 AM
SKF engineer
Default That's what I figured
When I did the brakes on my girlfriend's Trailblazer I was **** and took my time to take them off an put them back the way they came... When I saw them on the vette I was like, "NO WAY... those little pieces of junk again". They'll be gone the by the end of the weekend.
... and regarding the rubber band under the dash refernced above, I think mine broke. Should I install a larger one and call it a performance mod?
Thanks for the replys, have a great weekend.
Old Sep 28, 2007 | 09:17 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
SKF engineer
"and regarding the rubber band under the dash refernced above, I think mine broke. Should I install a larger one and call it a performance mod?"
You made my Friday morning!
Have a GREAT weekend!
Bill
Old Sep 28, 2007 | 12:39 PM
C4B4the04's Avatar
C4B4the04
FTWIW,
When the car is on the assembly line, the rotors go on and these hold them in place while the caliper and sub bracket are mounted. Once those parts are in place they are of absolutely no use on the car. I bought my car new and was VERY **** about taking EVERYTHING off the car had on it (plastic, tags, stickers, etc) and save it for the future. Why? I have no idea, it'll be "mint" condition if I ever sell it on ebay in twenty years (or cyber-bay by then).
BTW, you can always tell if a car has had the brakes worked over because of those. Had a dealership tell me they changed e-brake lining on my Silverado, only to find the clips still in place. Can you say "flatrate lazy tech busted" ?
Cassidy
To Easy brake question
