Need help with slave 'quick' disconnect!!!
Old Sep 29, 2007 | 03:20 PM
at88mph's Avatar
at88mph
From: The artist formally known as NONO5.0 Mobile, Al
Default Need help with slave 'quick' disconnect!!!
Tell me exactly why they call this thing a 'quick' disconnect because there damn sure ain't anything quick about it!!! How the crap are you supposed to get this thing disconnected??!?! I've tried using the Ford air conditioning + fuel line coupling disconnect tool (AmPro part # T70046 recommended in Dope's instructions but I just can't get it!! Any suggestions before I just cut the damn line
Old Sep 29, 2007 | 03:36 PM
vettenuts's Avatar
vettenuts
Took me three hours, what a pain. I tried everything, in the end I used two small screwdrivers. I had the master out so there was some slack in the line and then used a screwdriver to push down one side of the plastic release, then carefully pushed down the other side. Once I did this is popped right apart. I tried making tools and all kinds of tricks, but in the end the two screwdrivers worked for me.
Old Sep 29, 2007 | 04:10 PM
78Vette-SA's Avatar
78Vette-SA
I grab the brass sleeve, slide the tool behind the plastic bushing, push in and hold in place with same hand. With other hand, push other end in and then pull out. Pops out every time in about 30 seconds. Obviously if a header is in the way they it's much more of a pain.
I'll admit the first time took some getting use to. But once you do it, they are not hard at all.
Old Sep 29, 2007 | 09:30 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I use the tool from the snapon truck, for now I'd just cut the line on the slave side, always replace the slave, about $110
Old Sep 30, 2007 | 12:03 AM
at88mph's Avatar
at88mph
Thats what I did That's the whole reason I was pullin it anyway was to replace the slave.
Thanks everyone
Old Sep 30, 2007 | 12:34 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Two little screw drivers pressing in at the same time evenly will do the trick.
Old Sep 30, 2007 | 09:10 AM
Uncle John's Avatar
Uncle John
Rebuilt my McLeod master cylinder last week and had to do this. I made a tool by cutting a piece of tubing about 1/2 inch long, putting a slit in it and spreading it with a drift pin until it was the correct diameter. And yeah, I wanted to cut the damn thing out originally too.
Old Sep 30, 2007 | 09:49 AM
DRR's Avatar
DRR
Duke, Don't forget the remote bleeder.
Old Sep 30, 2007 | 10:50 AM
RAFTRACER's Avatar
RAFTRACER
Soaking the disconnect with pentrant of some variety well before trying to release helps immencely.............I have the special tool, but before I did I used an old school alignment shim attached with a needle nose vise-grip and that worked well....
Thoroughly soak it before trying to remove it and things will go a whole lot easier...You would be suprised how much dirt/grit etc gets down there with that plastic release sleeve...
Old Sep 30, 2007 | 07:46 PM
Roadrace65's Avatar
Roadrace65
I quit fighting with them in the car. I pull the driver side inner fender cover and disconnect the clutch line from the master, that takes a few minutes It’s so much easier to disconnect on a bench.
Old Oct 1, 2007 | 10:04 AM
at88mph's Avatar
at88mph
Fortunately its already installed. Thanks everyone
To Need help with slave 'quick' disconnect!!!
