5.3L vs 6.0L Heads????
The hp/tq difference is mainly going to be affect by the cam you choose and your supporting mods such as the intake and headers. You definately need some lt's and tune to get the most out of the heads and cam.
The same cam on 5.3's will have a little bit higher DCR than the same cam on LS6/6.0's. This higher DCR also benefits the low end, which is why I picked the 5.3's. The smaller intake runners on the 5.3s also helps low end, because it increases the velocity of the incoming air. I don't think it's a humongous difference, as is the case of AFR's, which are much lower (look at the difference between the low end on a set of AFR's vs. LS6 with the same cam, and you'll see significantly higher low-end torque).
As far as flow is concerned, my understanding is that LS6/6.0's will flow better than 5.3's at the same level of porting. In other words, Stage 1 6.0's will flow better than Stage 1 5.3's. I went with Stage 2.5 5.3's, which flow better than Stage 1 LS6's.
6.0 heads have 71.06cc chambers which lower compression. (mainly used on blower/turbo applications).
For comparison, LS1 heads are 66.67cc, and LS6 heads are 64.45cc.
The 5.3 heads have smaller 1.89" intake valve, same 1.55" exhaust valve.
As for port sizes,
LS1& 5.3 - 200cc intake, 70cc exhaust
LS6 & 6.0 - 210cc intake, 75cc exhaust
I know for a fact that I will not run forced induction on this car. So I wont be missing out on anything by going with the 5.3's, especially if Im looking to keep my compression up, correct? Again, still curious, how big of a cam can I run on the 5.3's without over stressing them?
I went with a 112 lsa which a real lopey idle compared to the 114. Good look on your decision.
You can run a cam way way way past your desires on the heads with dual springs, titanium retainers, bronze guides. A cam that will rev to 7k rpm. When you go with over .600 lift you need to chech piston to valve clearance. But with your goals you do not have to worry about.
I have the 5.3 stg 2 heads milled .010 and my next project is to super charge it. Who says you can run FI on 5.3 heads.
You will run in to piston to valve clearance with those heads and some of the bigger cams, but we're talking some big 'ole nasty, lopey cams in the mid 230's and above (just guessing here). Like Kendo said, a cam in the 220's range would make plenty of power without killing your low-end. Just make sure to mind your dynamic compression ratio; that single number has the biggest impact on low end. The larger duration and wider the LSA, the lower your DCR will be. You should target around 8.5 or 8.6. Look on LS1tech.com for "Pianoprodigy"s calculator. It will give you your DCR for a given cam and heads.
I have a 224/224 .581/.581 on a 112, and I'm hitting 410 at the wheel with 350 torque from 2,500rpm and on. It's a nice low-end. I'm around 8.5DCR. If you go with the same cam on a 114, the DCR will be lower, and the low-end torque won't be quite as high. If you go with a 224/228 on a 112, the DCR will be a bit lower, and the cam will be a little bit lower in torque down low, but will push a few more hp at the high end. Just research, research, research. Check out LS1tech.com and look for dyno graphs for various combos. You can see mine by searching here under posts started by me to get a feel for what my setup looks like on the dyno. Good luck.
