Warning...............
Old Oct 1, 2007 | 11:13 AM
Plasticfan's Avatar
Plasticfan
Default Warning...............
Don't get over confidant in your wrenching ability. I recently changed the diff fluid in my C5 and found a spot on the garage floor afterwards. When I put it back on the lift I found the leak to be coming from the fill plug.
I didn't see anything wrong with this fill plug gasket but it certainly did leak. :o If I did it again I would get a new gasket before I started. Since my small town dealer would never stock a part like that, I went to Autozone and got an assortment of drain plug gaskets. Seems to have done the trick. So I guess the moral to this story is you're never too old to learn.
Old Oct 1, 2007 | 12:20 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep. It happens to the best of us. How do you think I felt when I recently changed the rear end fluid. When I was all done and was draining the old fluid out of the drain catch pan into a funnel and found sealing ring in there?????
The ring sticks to the differential case and falls off sometime during the draining process.
Had to remove the plug, retain the NEW fluid in the rear, slip the ring on the plug, reinstall the plug back in the drain hole without loosing any fluid!
The rear end is maintained under a slight vacuum when cold and when you first remove the plug, not much leaks out. Only lost an Oz or so of fluid!
BC
Old Oct 1, 2007 | 12:59 PM
vmaquera's Avatar
vmaquera
Don't feel bad.
I pay a mechanic to do my mods and other repairs to my cars.
Somehow, everytime I try to do something to my car, I always screw it up and it winds up costing me more than if I had just had the mechanic fix it. :o
Fortunately, my mechanic is a friend of mine and loves working on my cars, so I can trust the work he does....
Old Oct 1, 2007 | 01:30 PM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default Fluid Change?
BC
Bill,
I have had the Coolant and Brake Fluid changed at my GM Dealership so far. My next door neighbor works in sales there so I get treated like royalty at the service department. Back to topic, I have an A4 transmission with about 43,000 miles on the odometer. Should I change the differential fluid myself and then have the dealer change the A4 fluid? It sounds like I can do the differential myself just with jack stands at home? Once of course I get a new drainplug washer. I did my own brakes and all of my own oil changes. With all of the threads about how you check your ATF level with the car running, I would rather let the GM service department handle that? Thanks for your input and any of the input from any of the other forum members who have changed their own differential fluid and ATF fluid.
BTW, I know that 43,000 may be premature but the cost of the fluid is so cheap that it seems worth the effort to have new fresh fluid in a 2001.
Old Oct 1, 2007 | 04:15 PM
BitViper's Avatar
BitViper
Don't feel bad.
You know..I do some wrenching on all my cars and I find it really satisfiying when Ive done the ded for myself..but theres allot to be said for being able to just writ a check!
Just like dirty harry said...
"A Man's GOT to know his limatations!"
To Warning...............
