Sensor Question
Old Oct 1, 2007 | 12:56 PM
Cujo67's Avatar
Cujo67
Default Sensor Question
What is the sensor located next to the oil pressure sensor on the top rear of the block for
a 1999 C-5.
Old Oct 1, 2007 | 01:10 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Cujo67 -
I believe you are referring to the vacuum switch located just to the passenger side of the oil pressure sending unit.
best regards -
mqqn
Old Oct 1, 2007 | 01:22 PM
Cujo67's Avatar
Cujo67
Default Thanks
Thanks for the info.
Old Oct 1, 2007 | 01:36 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Cam Position sensor! Nothing on the block is vacuum connected. Only vacuum related componets are on the manifold!
Old Oct 1, 2007 | 03:27 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Thanks Bill -
I was assuming that he as looking at the vacuum connection that is right next to the oil pressure sensor under the manifold.
Without pics or some other info, it's hard to even guess - but I like your guess.
best regards -
mqqn
Old Oct 1, 2007 | 09:42 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by mqqn
Thanks Bill -
best regards -
mqqn
Vacum connections and vacuum sensor (MAP)
Oil pressure sensor (tall one on right, CAM Sensor flat on left.
BC
To Sensor Question
