Does anyone know where to have a driveshaft balanced? I am replacing my couplers and DRM advised me to have the shaft balanced before I assemble it, trouble is I can't find anyone who knows what I'm taking about. Shops around here look at me like I'm an idiot, and the dealers want to sell me a new assembly for $800.00!
I've never heard of anyone balancing the torque tube/shaft assembly. Why would it get out of balance? Aren't the new couplers balanced? The center of the shaft should remain the same and I don't believe its indexed at all.
call Randy at DRM and ask him where they have their shafts balanced at - I don't know if DRM balances the driveshaft themself, or if they send them out of shop to have it done - but if DRM recommended doing it, I'd do it, cause DRM knows their stuff - you might have to send the shaft away to have it balanced since I'm guessing not every shop has balancing capabilities.
You don't balance the torque tube assembly, just the driveshaft assembly. I'm going to give Randy a call to find out more, like is it REALLY needed, and if it is, where the hell do I get it done!
We send our to a good driveshaft shop here in MN. They do some custom work on 4x4's, street rods, racecars and stuff like that. They also do a ton of clutch and CV joint work there too.
We assemble the shaft with the two ends on it and the rubbers intact. Then they come pick it up in their little white truck. Then the next day they drop it off again, needing a check
What they do at the driveshaft shop.
They spin the shaft to see if it's still straight, 50 percent don't need any work, about 10 percent of them get thrown away(Brian) The shop can straight out small bows. Then they spin it on the machine and balance it like you would a flywheel. There is a little tab that gm welds on them to help with balancing. Some times they have to move the tab and drill holes into them fine tune the balance job.
Is it really worth doing all this to a shaft. Well for the 90-175 dollars to make sure that you have done everything in your power to make sure the shaft lives a happy life.
Great, I guess Randy didn't want to talk to me. No one around here has any idea what I'm talking about. Unless he post the name of the drive shaft shop he uses I'm going to be calling him anyway. My guess is he'll post the name in less than 5 minutes.
Looks like I was mistaken regarding balancing since DRM is a respected tuner here on the board.
Last I knew the C5 didn't have a DRIVESHAFT. It has a TORQUE TUBE and two CV Axles. I believe you're calling the torque tube/shaft a driveshaft but its not. A driveshaft is used between a transmission and differential, however these are joined together in a C5 eliminating the need for a driveshaft. A torque tube is used between the engine and tranny.
I'm calling the shaft inside the torque tube a drive shaft. It may have another name but I don't know what it is. We can call them whatever you want, like drinking straw and toothpick. My toothpick needs balancing. the drinking straw is just fine and will hold my toothpick in place without any additional work. I just wish there was a toothpick shop in my area capable of balancing 3 piece toothpicks without carrier bearings.
You were right. They do send them out. Doug said Randy can't even balance a checkbook! At least I hope he can't. I'm going to send my shaft to Proven Force and tell them to put it on Randys account!
Hey Randy, you think those guys at Proven force would be interested in giving up their fixture design to a local shop down here? They said they would like to know how they hold on to those things in their balancer. The way they see it, more and more of these things are going to need balancing as the C5s get older and they want in if the fixturing isn't too complex. I'm going to take mine down there when I get it out so they can see what they're up against.
some one better get to know the car better, , there is a drive shaft. Simply, a torque tube is a enclosed driveshaft. BUT,,,as with most "driveshaft cars, the rear end moves up and down, thus the need for u-joints with a large amount of movement in them for the suspension to work. Most "torque tube' cars, the tube joins the engine/trans/rear end ( some have the trans in front, other in the rear) and the entire drivetrain iS mounted farily solid, with only the wheels moving up and down ( ala C5)..so both have a driveshaft,,that would benefit from a balance job.
just cause you cant see it,,,dont mean it aint there.
He's right. My wife does my personal and Doug takes care of the shop stuff. I am really good at spending money!!! If you put it on our account, then I will just transfer that to JD's bill
You can call and ask them. They are pretty nice guys and should be able to help out your local shop. Or just send it up there.
I would just bring it into them and have them take a look at it. If there isn't a guy over 50 years old there, then just run.
JD would never catch it, He has payments to you guys EVERY month. But his wife would kick my ***! she doesn't miss a thing!
Matter a fact, the guy at my local shop has been there sence they built the building! He really knows what he's doing so maybe he can figure somthing out with reguards to these G.M. toothpicks
Believe it or not, nothing is damaged. The carrier bearings are toast, actually 1 of them feels a little gritty, but everything else seems fine. Here's a picture of 2 old couplers and 1 new one.
