drivers side window scratched?
Old Oct 2, 2007 | 10:42 AM
02gt350's Avatar
02gt350
Default drivers side window scratched?
look as though something inside the door put a scrtach going up the window. has anyone noticed this before?
Old Oct 2, 2007 | 12:41 PM
LETHL_C6's Avatar
LETHL_C6
I have the same thing on my passenger window but its on the outside.... a vertical perfectly strait scratch almost the entire length of the window.
Old Oct 2, 2007 | 12:47 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It is from dirt and sand in the weather stripping.
Roll the window down. Get a flat head screwdriver, wrap a towel around the blade, run the blade between the 2 strips.
Watch how much dirt comes off the strips.
Old Oct 2, 2007 | 02:03 PM
02gt350's Avatar
02gt350
yup. how mine is. i can get my damn fingernail in it. as straight as it is. it has to be something in the door.
Old Oct 2, 2007 | 02:11 PM
Billdog350's Avatar
Billdog350
There is a fabric/fuzz metal guide in there if I recall. All it takes is the fuzz to wear off and/or rocks to get wedged in there and you get a nice scratch. Tints seem to make the issue worse. Anyone know if you can polish glass to remove the scratches?
Old Oct 2, 2007 | 02:31 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Bill, start sanding
Old Oct 3, 2007 | 06:21 AM
RajunCajun2001's Avatar
RajunCajun2001
Old Oct 3, 2007 | 10:01 AM
TNX ZORA's Avatar
TNX ZORA
Even a very close inspection with a magnifying glass didn't reveal whatever caused the side glass scratches on our C3 - even after the felt strip was removed. A new one was installed as a precaution. I personally think it is often tiny pieces of quartz rock, or the like, that do this damage and not ordinary sand and dirt. Also, on some cars, the fasteners can rub on the glass when the felt wears down enough. It is practically impossible to remove these scratches.
Old Oct 3, 2007 | 10:10 AM
TEXHAWK0's Avatar
TEXHAWK0
If it is on the inside, the clearance between the glass and the regulator assembly guides is very close. I noticed when I replaced mine that without the inside door panel on, the glass actually would rub on the rails, so if the inside panel does not keep the glass in position it could scratch the glass.
To drivers side window scratched?
