Let's talk about ping
So my questions are, what is ping? (I'm guessing a pre-detonation of unburnt fuel) what bad things am I doing to my engine with all this ping? How can I rid myself of this terrible scourge?
this is caused by a low Octane rating on the fuel you are using more often than none - most new on board diagnostics systems are smart enough to retard the timing on these newer engines to help reduce pinging under a hard load or in some cases when just cruising along.
I see that you have done heads and cam work so you are probably running a bit higher compression than what the car had stock - to keep this from happeneing you are going to need to run a higher octane fuel - probably above the 91/92 you can normally find at the pump
residing in Virgina you might be able to find 100 octane right at the pump a bit more easier than I can being here in California.
You can always have a custom tune put on the car to help with the pinging issue as well from a repituable dyno facility in your area - be prepared to drop a good amount of cash for that.
