Front spoiler
Old Oct 7, 2007 | 03:35 PM
AU N EGL's Avatar
AU N EGL
Originally Posted by samy segura
Ok, then how do I use the clip-on bolts, they will line up with the inside edge of the spliter, where the plate's holes won't.
Samy, that I dont know.
Can you take a picture of the front bumper, and the splitter underneath. Pics from the front and the back sides??
Old Oct 7, 2007 | 03:38 PM
samy segura's Avatar
samy segura
I will, as soon as I get it back, I had to return it, the bottom was warped and wouldn't align with the spliter anymore. That's what I get trying to make my daily driver a track car....
Old Oct 7, 2007 | 03:47 PM
AU N EGL's Avatar
AU N EGL
Warped? My ACP nose was real flexable, about 5 lbs LESS then the OEM.
I ( or the Body Shop) just put the nose on, then they ( with my input ) pop riveted the overlay splitter on.
I also have a front flat diffuser under neath.
Wait, did you say Track car? do you have a 1" rear spoiler that points UP at 45* angle? if not, you will have too much down force on that splitter.
also what suspension are you running??? I have a T1 and some times that is not stiff enough with the downforce
Now the bad news. You will loose top end speed do to the extra down force. I lost 4 mph at 4th gear red line. But gained 7-10 mph on high speed sweeping corners.
Old Oct 7, 2007 | 03:54 PM
samy segura
I have the Pfadt coilovers on, and I intend to install a APR wing. My problem is to be able to keep a streetable car, the spliter as a permanente part, wouldn't clear any street in my area. Do you have pics of you diffuser?
Old Oct 7, 2007 | 04:58 PM
AU N EGL's Avatar
AU N EGL
Sorry no diffuser pics.
My splitter does not either. I have 3 /4" ground clearance under the splitter
