Check Engine
Old Oct 3, 2007 | 05:51 PM
zwam05's Avatar
zwam05
4th Gear
Default Check Engine
I am very new to Corvettes but willing to learn....Check Engine Warning has come on (stays on) In checking the DIC codes review I see PCM PO442 H C.......any suggestions?
zwam05
Old Oct 3, 2007 | 08:41 PM
MNCrystalRed2011's Avatar
MNCrystalRed2011
Make sure you gas cap is on securely.
Old Oct 3, 2007 | 11:01 PM
vincentjames501's Avatar
vincentjames501
More info:
http://www.gearchatter.com/viewtopic10340.php
Old Oct 4, 2007 | 10:10 AM
zwam05's Avatar
zwam05
4th Gear
That was my first move...I purchased a new fuel cap....looks like I should wait to see if 40 cycles clear the error
Old Oct 4, 2007 | 10:12 AM
zwam05's Avatar
zwam05
4th Gear
Great help thanks for the info...
Old Oct 4, 2007 | 02:35 PM
trussme's Avatar
trussme
use this to clear the code:
The "diagnostic display" mode is entered with the following procedure:
1. Turn on the ignition but don't start the engine
2. Press the "reset" button to turn off any warning messages
3. Press and hold "options"
4. While holding "options", press "fuel" four times within a 10-second period
When first engaged the on-board diagnostics go into an "automatic" mode which shows all parameters: PCM-TCS-RTD-BCM-IPC-radio-HVAC-LDCM-RDCM-SCM-RFA. If there are no problems, you will see "no more codes" on the ICP display. The computer will show two kinds of codes, "current" and "history," designated "C" or "H". A current code indicates a malfunction is present in the system whose module is displaying data. A history code indicates a past problem. When the screen displays "manual diagnostics," select the desired module by pressing the "options" button to go forward or the "trip" button to go back. Press "gages" to go forward or "fuel" to go back. To exit the diagnostic mode at any time, press "E/M".
If you want to erase or "clear" codes, press "reset."
Old Oct 4, 2007 | 05:17 PM
zwam05's Avatar
zwam05
4th Gear
Done....back to normal.....thanks to all
To Check Engine
