fog light out
Old Oct 3, 2007 | 07:54 PM
red88L98convert's Avatar
red88L98convert
Default fog light out
okay, sounds silly, but is there anything i need to know about changing out the fog lights? my pass side light went out today and i am just hoping i dont have to take the tranny or windshield out to change it!!
Old Oct 3, 2007 | 08:18 PM
Rays Vet's Avatar
Rays Vet
iirc you can access it by raising your headlights and reaching in and twist.
Old Oct 3, 2007 | 09:10 PM
kg54trains's Avatar
kg54trains
Default fog lights
when you change your fog lights switch from 38watts to50watt bulbs.
to replace... manual raise the headlights; disconnect the lead from the lights; now remove the headlight top panel and the plastic trim that surrounds it. Now if you have average arms you can reach down past the headlights to replace the fog lights.They just turn and pop out, but it is a tight squezze past the headlights.
Old Oct 3, 2007 | 10:23 PM
71sx's Avatar
71sx
You just need to raise the headlights (hood open) and remove the black side-panel on the inboard(engine side) of the headlight assembly. There are about 4 screws involved. You should have enough room to reach down and unplug/remove the burned out bulb.
Old Oct 3, 2007 | 10:37 PM
Johnny Hardcore's Avatar
Johnny Hardcore
You don't need to disconnect anything! Turn your headlights on, then back them off one click. This will keep the headlights up.
Then if you have small arms, Forunately for me, I don't (my wife did it for me, she also changed my and my brothers turn signal lights),you can reach down and unplug the fog light. I'm a big guy with formadable biceps and I could reached the bulbs for removal myself....if I had to.
Getting the bulbs out was a little tough but she got them. FYI. It gave her a much harder time getting the clips in correctly, but she finally got them. Have who ever does the removal/install, use rubber gloves without powder. Don't want oils on the lense.
Old Oct 4, 2007 | 08:19 AM
rws.1's Avatar
rws.1
If you have man sized forearms you have to do it from under the car....
put the car on a ramp, jackstands or a lift...
remove the access panel on the underside of the car just behind the front fascia. (about 5 bolts), the fog lights will be readily visible and reachable.
Old Oct 4, 2007 | 09:59 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Go with a higher wattage and Aim them, it makes a world of difference.
http://www.c5forum.com/diy/fog_lamps.php
Old Oct 4, 2007 | 01:57 PM
red88L98convert
thanks for the help guys.
one more thing, where should i get the 50w bulbs?
Old Oct 4, 2007 | 03:52 PM
71sx's Avatar
71sx
Let us know what approach you took. I'm 210 lbs. and found that my arms could only squeeze into the space if I took the side-cover off the headlight assembly. Once I did, I had enough space to work. The last thing I'd try is popping the the splash guards off from underneath, that's more effort than might be necessary.
Old Oct 4, 2007 | 07:30 PM
bighank's Avatar
bighank
Default USE 885s on BOTH SIDES and SEE THE LIGHT
885s are 50 Watts and won't melt anything.
Reaim them too with a torx wrench. They are usually set too low.
Park about 20' from a garage door or wall and use your headlights as a guide. BIGHANK
Old Oct 8, 2007 | 01:33 PM
red88L98convert
cool, now, where do i get the 885's???
Old Oct 8, 2007 | 04:11 PM
bighank's Avatar
bighank
Default Got mine at local auto parts store
I think they were about a dollar and change.
Cheap upgrade
Not $$$$$$ HIDs but a BIG difference. BIGHANK
Old Sep 27, 2008 | 02:52 PM
dberry08's Avatar
dberry08
Thanks for the input, the wife did an excellent job of getting her hands in there. I ended up having to take the plastic trim out anyway to tighten them, but no need to put the car up on ramps.
Old Sep 27, 2008 | 07:44 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If you get the lamp out and find out its still good, it happened to me. It was a bad ground pack on the right forward frame rail. The particular ground wire, its crimp on the wire to the pin was bad.
Old Sep 28, 2008 | 06:53 PM
lucky131969's Avatar
lucky131969
Just the tranny, you only have to remove the windshield for the side marker lights..
Old Sep 28, 2008 | 08:10 PM
bighank's Avatar
bighank
Default Use 885s they are almost as bright as headlamps
Changed mine about 3 years ago anbd reaimed. You won't believe the difference. If you can't reach them thru the headlight opening you can raise the front of the car and remove about 3 or 4 screws on the splash guards. I did it this way to inspect things underneath.
BIGHANK
Old Sep 29, 2008 | 09:19 AM
jovette's Avatar
jovette
This was the method I used when I replaced my OEM bulbs with the 885s I got from Auto Zone. It's really a piece of cake once the shield is removed, and yes do use the powder free gloves when handling the new bulbs.
To fog light out
