Ok im probably retarded but....
Old Sep 26, 2008 | 08:21 AM
pimpjames's Avatar
pimpjames
Default Stall problem? ....
I tried going for a sprinted run this morning with the dynolicious program and when I try to brake stall it gets to about 1500 RPM's and then and drops a lil bit and goes back to 1500 again like it is bouncing at 1500 RPM's? Normally it would fry the tires but I have a 3200 stall installed and maybe need to do something to get it to power brake? It's like my engine won't rev past 1500 RPM no matter how much gas im giving it if the brake is held down. As soon as I let off though at 1500 it initiates Warp 9
Old Sep 26, 2008 | 08:26 AM
Mad Dog Peter's Avatar
Mad Dog Peter
I wish I could comment, but you are speaking Chinese to me. I just drive my Corvette and have fun! You sound like a pro and unintelligible to a noob like me!
Old Sep 26, 2008 | 01:14 PM
verano29's Avatar
verano29
Traction control on??
Old Sep 26, 2008 | 02:41 PM
oakvillec5's Avatar
oakvillec5
What the heck are you talkin' about?
Old Sep 26, 2008 | 03:08 PM
VinnyT's Avatar
VinnyT
Probably Torque Management. It will reduce power by retarding the timing. GM has this built into the PCM to reduce driveline stress.
Old Sep 26, 2008 | 03:19 PM
dougbfresh's Avatar
dougbfresh
dynolicious program ?????????????????
Old Sep 26, 2008 | 04:49 PM
PaintballaXX's Avatar
PaintballaXX
Its an application for the Iphone that uses the built in accelerometers to estimate your horsepower, braking performance, lateral g's in turns, 0-60 times, etc. My friend has 1, takes alot of calibration to get it accurate.
Old Sep 26, 2008 | 06:49 PM
4DRUSH's Avatar
4DRUSH
You need to disable brake torque management from your PCM. Been there.
(Your not Retarded)
Old Sep 26, 2008 | 07:27 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
(Your not Retarded)
Been there done that huh Jay?
Old Sep 27, 2008 | 06:45 AM
pimpjames's Avatar
pimpjames
(Your not Retarded)
Awesome thanks! I'll have my tuner do that this week.
Old Sep 27, 2008 | 09:44 AM
itzza427's Avatar
itzza427
Just get an M6 and you can leave at whatever RPM you want!!
Old Sep 27, 2008 | 10:18 AM
C5XTASY's Avatar
C5XTASY
You have Generation I Active Handling. Generation 1 Active Handling will not allow you to brake torque beyond about 1200-1500 rpms. It will downpower the engine and rpms will bounce back and forth as you describe. That's one of the differences between Generation I Active Handling (1998-2000) and Generation II Active Handling (2001-2004). Generation II allows you to brake torque. You may want to try launching with Active Handling turned off, and then immediately turn it on when your foot comes off the brake. Your 3200 stall is allowing the rpms to more easily climb higher than with the factory stall.
Ed
Old Sep 27, 2008 | 02:01 PM
pimpjames's Avatar
pimpjames
Ed
Oh Nice! I'll try it in a bit and let you guys know the result
Old Sep 29, 2008 | 10:12 AM
pimpjames's Avatar
pimpjames
Well that Def. worked when i turned AH off.. left a plume for miles lol. Think ill be leaving it on for now until i get some drag radials back on
To Ok im probably retarded but....
