0 Oil Pressure!
[/IMG]Ls6 motor swap, stage 3 ls6 heads, titanium retainers, valves, etc., double valve springs, chromoly push rods, texas speed camshaft(233/239 .593/.603), double roller timing chain,fast 90mm intake manifold, ported and a brand new ls2 throttle body ported,vararam intake and larger air bridge. kooks 1 7/8 headers, custom exhaust, basani x pipe. ghl bullet exhaust, spec three clutch and a fidanza flywheel
Not running anything like that, just headers and a cat back with a shot of giggle gas, well not running the gas yet, just showed up today.
but this weekend, its gonna be on it!
How are you liking that cam??
Chris
Please-- dont run her again, have heard the horror stories!
It does not sound like a sensor though, maybe the stars aligned and knocked your pump or seal out at the same time??
Ill look into previous threads for ya and report.
Chris
I kinda get the impression that you're saying that because of this bad experience that a torque wrench isn't to be trusted. I hope that's not the case.
I too use the "hand tight" technique on many fasteners, especially if they are of a more non-critical nature or they just can't be accessed to get a torque wrench on. The areas where I tend to focus on torque wrench use are generally steering/suspension/lug nuts (safety) related OR in an area where too much/little torque can result in a big $$ and/or major inconvenience i.e. cylinder heads, crankshaft main caps, bolts that screw into (soft) aluminum and the like. Some guys want to use a torque wrench on EVERYTHING, in large part because of : "well GM has a torque spec and if it wasn't important, GM wouldn't publish it".
That's just unrealistic in the real world and being able to use common sense, combined with experience, helps keep someone from falling into that trap. The first time I removed my intake manifold, I couldn't help but notice how long these bolts are in relation to their small diameter. The longer a bolt is that is of a small diameter (especially assuming it's a probably a Grade 3 or maybe 5 steel), means it's much more likely to twist and either break or strip threads if you're not careful. Also, a plastic manifold can be very unforgiving to too much torque and there's always a risk of hearing that dreaded "snap", which is usually NOT a good sign or, worse yet, that sickening feeling you get when all of a sudden the force you're applying becomes TOO easy (translation: usually a stripped bolt hole). BTDT
I've kinda had to re-adjust the way I deal with fasteners in these (mostly) aluminum LS engines after having dealt with cast iron (Chevy and Pontiac) engines in the past. Mainly the MUCH lower torque values overall plus I now tend to pay much more attention to the use of anti-seize and clean threads, etc.Doesn't make me an expert but I, like most people, have screwed something up in the past and have learned from it and try to help out others where I can and I'm always willing to learn something from others too. Especially here on the forum where the collective wisdom of so many people here are a HUGE asset to me and others.
Sorry for the long post.
I actually just picked up a mirror ealier today. haven't got a chance to check yet, I will prob do that first, and if i cant see anything or solve the prob ill rip that manifold right off,lol. I hope I see the prob and can jsut plug it back in but life never seems to be that easy these days!!
Thanks for all the help everyone, I will post the results
I'll be down there in a few weeks with the vette, KY, PM me, we will cruise!
2 black vettes, only thing better is 3!
Chris
That's always a good idea. The biggest problem I have is big hands which I have chewed up many times trying to squeeze into that tight (for me) area behind the manifold.
I'm suspecting a loose/leaking brake booster vacuum hose or MAP sensor grommet as a good reason for the engine dying.
well unless the pump is bad, bc its ls6 ported oil pump. i dont think its that though. I guess I'll have to remove the intake tonight and have a closer look.
