Headlights Dim when Braking?
Old Oct 4, 2007 | 01:26 PM
MN81C3's Avatar
MN81C3
Default Headlights Dim when Braking?
Ok - I'm new to C5's - and may be just looking for problems. Last night, I noticed when I stepped on the Brakes, the Headlights dimmed slighlty. At first I thought i was nuts - but my wife also notcied it. I then noticed the Battery Gauge dropped a little also. Is this a weak battery? Or something larger?
Old Oct 4, 2007 | 02:33 PM
thisMSGgood4me's Avatar
thisMSGgood4me
Yes, it could be a weakening battery. How old is it? You might think about getting it load tested.
Old Oct 4, 2007 | 03:04 PM
slo poke's Avatar
slo poke
I also have the same problem on mine
Old Oct 4, 2007 | 03:31 PM
MN81C3's Avatar
MN81C3
I bought the car this past weekend with only 4,451 miles on it. The previous owner basically did not drive it. I does not have the orginal battery in it - it has a Sears Diehard Platium - but it looks small in size. I suspect it never had a battery tender on it. I will get the battery checked. Should get an orginal GM battery seeing as the car still has all the paper tabs under hood and on the supension parts?
Old Oct 4, 2007 | 03:32 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Are you seeing this while driving?
If so, try doing it while parked in your drive way in Neutral/park.
Old Oct 4, 2007 | 03:46 PM
noahdr's Avatar
noahdr
^ Engine ground?
Mine does the same thing but I'm pretty sure its my alternator failing. The headlights also go dim if I roll up the windows.
Old Oct 4, 2007 | 07:04 PM
Point & Shoot's Avatar
Point & Shoot
It is either the alternator or the battery.
Mine was the alternator.
Good luck !!
Old Oct 4, 2007 | 08:24 PM
thisMSGgood4me
Good luck !!
It can be either one, but I'd start with the battery because it's easier to check and replace than the alternator. If it turns out the battery is good, then I'd check the alternator next.
Old Oct 5, 2007 | 12:00 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Do the "big 3" mod. This will hold you over until you figure out the problem.
Big 3: is 3 lengths of 4 awg wire from
Alternator (+) to battery (+)
Alternator mounting bolt to Frame
Battery (-) to Frame
this significantly reduces voltage drop across your electrical system. (the primary cause of headlight dimming)
Old Oct 5, 2007 | 09:37 AM
ronwc's Avatar
ronwc
Mine did that when I first bought it, it was a loose/dirty battery connection, simple fix -
Old Oct 5, 2007 | 11:20 AM
MN81C3's Avatar
MN81C3
Thanks everyone - I will check it out this evening again at idle then will start with making sure the connections are clean and solid. Ten move on to the Battery check and Alt if necessary. I post what i find so it can maybe help someone else.
Old Oct 6, 2007 | 01:04 AM
Hoosier Red's Avatar
Hoosier Red
Same problem here that I just noticed in the past week. I would have been surprised if I hadn't noticed it in the previous 25,000 miles that I've driven my 03. I walked out to drive it home this morning and had the following sequence of events:
1. the remote wouldn't work - had to use the key.
2. the lights didn't come on when I open the door - assume the battery is dead and I'm ticked b/c I've been up working all night and the battery was an Optima red top that's only a year or so old.
3. try to start the car and it actually starts - happy that I'll get home, but still mystified by #1 and #2.
4. car dies as I back up and column locks - now I'm pissed again.
5. Restart car and I'm able to get home.
Haven't had a chance to check it again today, but I'm assuming that I'm going to have a little fun chasing this gremlin down. Any ideas beyond battery, connections, etc.? As additional info, had to have the ABS pump and all the AH electronic module replaced a few weeks ago - fortunately under GMPP as it would have been a $3300 bill. I wondered if that played any role in the headlight dimming with the brakes only b/c of the proximity in the fix and the new problem.
To Headlights Dim when Braking?
