Key Stuck In igntion!
Do you have a heavy key ring with lots of keys on it? That is the most common reason for the cylinder to wear out. Best to just have the key and the fob, and carry other keys on a seperate key ring.
You should look into replacing the lock cylinder soon. The dealer can do it so that the car does not need to be re-keyed. They can "build" a new ignition lock to accept your current keys. Otherwise you either have to have a seperate ignition and door key, or have the door lock replaced also.
I'm guessing (let me emphasize GUESS) that what you were seeing was the Theft Deterrent system not working correctly (or correctly, depending on your point-of-view).
If the lock cylinder was out of alignment, it is possible the "chip" or resistor in your key was not being read correctly. Was your SECURITY lamp flashing when you started the car and were unable to drive it? If the key can't be read, the engine will start, but as soon as you try to drive it the fuel to the engine is cut off by the PCM.
This is most likely why your key would not pull out of the ignition and the reason you activated the Pass-key/VATS protection is because the key was already inserted into the ignition when the battery was connected so the BCM got confused, pulling the key out and reinserting it allowed the BCM to read the resistance of the pellet on the key which took care of that problem also.
If it happens again remove the center console and look at the forward end of the shifter plate, there is a cable that runs to the back of the ignition switch.
