Passanger Side Headlight Not Aligned
Old Oct 6, 2007 | 03:24 PM
PaintballaXX's Avatar
PaintballaXX
Default Passanger Side Headlight Not Aligned
Hello all.
I was recently fixing the driver side headlight gear (which went well until i noticed the car was leaking oil and the low oil level dic message went on) and when I test the headlights i noticed scratches on the passenger side headlight cover. The scratches were on the side of the cover which faces the rear of the car. When the passenger side headlight flips up, the rear of the cover gets very close to the hood. It only has a paper thin gap. When closed, the gap is bigger and normal looking, but not as big as the driver side. Also when closed, the cover is flush with the hood, so those 4 screws under the cover, I'm assuming, are set in the right spot. Does any1 have any ideas on why this is happening and how I can fix it?
Old Oct 6, 2007 | 07:49 PM
Bugaboo's Avatar
Bugaboo
Now that stumps me..what does the screw at the very back of the cover look like. Its just a single screw...........tight?
Old Oct 6, 2007 | 08:51 PM
PaintballaXX
Is their not two screws in the back of the cover and then 1 on each side (except the front)? Which screw are u talking about?
Old Oct 6, 2007 | 09:06 PM
Bugaboo's Avatar
Bugaboo
You're right, 2 screws.........been awhile since I've been in there.
Old Oct 6, 2007 | 10:42 PM
jdmvette's Avatar
jdmvette
Night Owl for life
here's an awesome post with pics that show how to adjust your headlamp door gaps:
Originally Posted by NONO5.0
Ok, to fix this:
Adjust these little by little *YOU ADJUST THE TORX HEAD, NOT THE WHITE NUTS:
To fix this:
Adjust these little by little. They will allow you to move the frame side to side and back and fourth:
Just take your time!
For future use, here is a good link for others who may come across this thread:
http://forums.corvetteforum.com/show...headlight+gear
Old Oct 6, 2007 | 10:44 PM
PaintballaXX
Edit: nevermind that next part is probably it, thank you very much jdmvette.
To Passanger Side Headlight Not Aligned
