weight reduction question
Old Oct 7, 2007 | 02:58 AM
9secnotch's Avatar
9secnotch
Default weight reduction question
I have a 2003 z06 and im looking to reduce weight. Does anyone know how to reduce weight in these cars?
Old Oct 7, 2007 | 03:04 AM
Smokin Joe's Avatar
Smokin Joe
take out your interior. lighter flywheel.
Old Oct 7, 2007 | 03:14 AM
9secnotch's Avatar
9secnotch
anything else?
Old Oct 7, 2007 | 03:18 AM
Last C5's Avatar
Last C5
Lightweight battery, race seats, delete the air pump, CCW wheels, aftermarket X pipe, and beyond that you start loosing the streetability of the car.
Old Oct 7, 2007 | 04:43 AM
JETZ's Avatar
JETZ
Z06's are already light!
If you're building a race car go at it, but for the street fogetaboutit.
Replacing parts with lighter CF pieces cost big $ for a few pounds saved. 100 lbs. are worth 1/10 sec.!
Your car would be worth nothing in resale all stripped out, stick a blower on it, and call it a day!
Old Oct 7, 2007 | 05:33 AM
vettelover84's Avatar
vettelover84
Of Course you could put a super charger or TT setup on your Z!!! It would add weight sure, but the power to weight ratio would be better!!!
Old Oct 7, 2007 | 07:38 AM
AU N EGL's Avatar
AU N EGL
take out the radio and speakers, remove the AC condensor.
There is a "sticky" in the C5 General section about weights and measures. About 1/2 down are the weights of many parts/
Old Oct 7, 2007 | 11:27 AM
9secnotch's Avatar
9secnotch
the car is an 11.0 car already with bolt on's in 80 degree weather so im looking for alittle weight reduction to slip in the the 10's.
Old Oct 7, 2007 | 12:37 PM
khadiyev's Avatar
khadiyev
take out the power steering pump.. works on mustangs.. for drag racing.
Old Oct 7, 2007 | 06:29 PM
uracowman's Avatar
uracowman
1)wheels and tires.If you have runflats you need to get just regular radials and a lightweight set of wheels.
Apart from this I would never consider taking anything else out due to resale,unless you plan on keeping he vehicle for tracking/dragging.If you are not planning to do any of these two,there really is no point of you gutting out the car.The z06 isn't fast enough already?
Old Oct 8, 2007 | 03:50 PM
9secnotch's Avatar
9secnotch
its fast enough but i need a 10 ten slip, so before i start thinking about the next step im trying to reduce alittle weight. as for resale, im not thinking about that. im interested in going fast..
Old Oct 8, 2007 | 05:40 PM
123sugey's Avatar
123sugey
Dig
passenger side airbag, no washer fluid, remove front swaybar, remove passenger seat, a/c delete
Old Oct 8, 2007 | 05:41 PM
123sugey's Avatar
123sugey
Dig
i forgot... my lakewood 90/10 shock conversion saves a little weight and better traction
Old Oct 9, 2007 | 01:12 AM
Blorton's Avatar
Blorton
Buy one of these kits and move your drivetrain over.
http://www.factoryfive.com/gtmhome.html
2400lbs light enough for you?
Dan
Old Oct 10, 2007 | 02:37 AM
9secnotch's Avatar
9secnotch
what about removing the ac compressor? and the electric water pump anyone run one of those and make more power?
Old Oct 10, 2007 | 07:01 AM
AU N EGL's Avatar
AU N EGL
yes and yes
Old Oct 10, 2007 | 08:55 AM
Blorton's Avatar
Blorton
If you do decide to remove the AC, please go to a shop first and have them suck out all the refrigerant. Besides being eco friendly, that avoids you having any undesireable moments when removing the system.
Removing the stereo components is good for a bit of weight, as is the AIR system if you can get those codes disabled. That won't be enough to drop much time off your dragstrip passes, but it'll help.
Speaking of which - are you a scrawny dude, or more along the lines of someone who doesn't pass up extra trips to the all you can eat buffet? Without getting too personal, a lot of vettes could do with losing 50 pounds off the driver's seat.
Cheers!
Dan - carrying 30 pounds of penalty weight myself.
To weight reduction question
Old Oct 10, 2007 | 09:03 AM
fsuforever's Avatar
fsuforever
QUOTE=9secnotch;1562218385]its fast enough but i need a 10 ten slip, so before i start thinking about the next step im trying to reduce alittle weight. as for resale, im not thinking about that. im interested in going fast..[/QUOTE The Quickest way to get to the 10sec mark & the cheapest would be to add a 100 Shot of NOS ,u may see 10;50s [
Old Oct 10, 2007 | 11:01 AM
nickolbag's Avatar
nickolbag
If you went 11.0 in bad weather just wait for good weather and you will get your 10 sec slip. No need to reduce weight. If you want to drop a few pounds without going crazy jsut remove the passenger seat and front sway bar.
Old Oct 10, 2007 | 12:24 PM
02gt350's Avatar
02gt350
CCW wheels? those are heavy as FACK!!!
