Sport seats interchangable?
Old Oct 7, 2007 | 11:05 AM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
Default Sport seats interchangable?
So my driver seat doesn't work so well, but the passenger side works perfectly can I swap them out???
Old Oct 7, 2007 | 11:11 AM
DeeGee's Avatar
DeeGee
There was athread discussing this not too long ago. A search might pull it up
I think you can but you'd need to swap over the electrics panels for the seat controls.
Old Oct 7, 2007 | 11:49 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
you can swap parts that work better over to the dr's side, the upper lower seat frames are the same, of course the tracks are different, inner upper leather skins, lower skins are the same except for the holes where the controls are
Old Oct 7, 2007 | 03:20 PM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
Thanks I am in the process of buying a control module and when I get it I will do the rocking seat fix and replace it and hope for the best. The seat will not go all the way back and the button will only move the seat forward or down not up or backwards. Also those little switches behind the larger switch what do they do? I press them and I here a noise but don't see anything going on.
Old Oct 7, 2007 | 03:59 PM
SteveDoten's Avatar
SteveDoten
you can seperate the switch, most likely water caused one of the paths to 'cross', the air tubes are severed or leaking, yank the seat and eval.
www.vetteessentials.com for the seat how to
To Sport seats interchangable?
