Question About Error Code
Old Nov 13, 2001 | 09:53 PM
C5SilverBullet's Avatar
C5SilverBullet
CI 4, 5 & 9 Veteran
St. Jude Donor '08-'09-'10
Default Question About Error Code
I looked up one code that the car was sending and it is IAS High Voltage. Can anyone help? :confused:
Old Nov 13, 2001 | 10:36 PM
1SGRET's Avatar
1SGRET
St. Jude Donor '12-'13
Default Re: Question About Error Code (C5SilverBullet)
Intake air tempuratue sensor bad. About $15.00 from Chevy parts department. You can install yourself in about 2 minutes. I would try unplugging and plug back in. Check terminal end for dirti or broken pins, has 3 if I remember correctly. If a new sensor doesn't correct the problem could be a defect in the wires.
