Head question
Old Oct 8, 2007 | 06:56 PM
Mpwr's Avatar
Mpwr
Default Head question
I was speaking to someone today and I was saying that alot of people are running afr heads and and he stated that ls6 heads are better just get them ported and polished. Anyone agree or disagree?
Old Oct 8, 2007 | 07:17 PM
vettenuts's Avatar
vettenuts
Two issues I see with this argument. First, the AFR's have the same port size and flow more, thus more velocity. Second, as you open up the stock heads you thin them out, that's OK but some have had issues with the rocker area breaking due to the higher spring loads coupled with the thinner sections. AFR's are a premium head. It all depends on your budget.
Old Oct 8, 2007 | 07:21 PM
02MillenniumVette's Avatar
02MillenniumVette
Old Oct 8, 2007 | 08:06 PM
speedsk899's Avatar
speedsk899
You might want to look at the Dart Pro1's. 225 intake runners out the box, fully assembled and handle 600 lift for $1600 from summit.
Old Oct 8, 2007 | 11:40 PM
Mpwr's Avatar
Mpwr
A tuner told me this... i dont want to bad mouth anyone, so i wont say who. But I asked him again just to make sure I heard correctly and he said the stock heads are better then afrs..so im a little lost
Old Oct 9, 2007 | 07:37 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Cartek makes great power with LS6 heads
Cartek makes great power with LS6 heads. Look at the track times the cars run. AlexV runs 10.4's with 243 castings.
Mike can do some great stuff to these heads.
Bob K.
Old Oct 9, 2007 | 08:28 AM
CTD's Avatar
CTD
Based on budget or performance....
Old Oct 9, 2007 | 12:17 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Depends on whose ports are in the LS6 heads. Some ports are better, some are comparable and some are worse.
Old Oct 9, 2007 | 12:31 PM
MikeM@ECS's Avatar
MikeM@ECS
She'd be hot if her face wasn't so ugly!
Old Oct 9, 2007 | 03:45 PM
Mpwr's Avatar
Mpwr
Well thanks for straightening that out...I called you yesterday( about a S/C kit of a H/C setup) and found you very helpful but just wanted to make sure what i heard was correct.
You will be hearing from me soon
Dan
Old Oct 9, 2007 | 03:57 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Hey Chris, Do you guys offer Ported/Polished heads ?
Old Oct 9, 2007 | 04:42 PM
Cruise-In V Veteran
Yes we do.. there are quite a few options depending on your goals. We have used Trick Flow's, AFR,s ETP's as well as a few different GM castings with CNC ports. Best bet ia to give me a call and I will be happy to recommend a nice head depending on your application and budget..
Old Oct 9, 2007 | 05:56 PM
Corvette-Chris
St. Jude Donor '08
I have a set of AFR's I want to get rid of. Practically brand new but I do not want to flycut so I need something else. Maybe some Ported LS6 and a fast 90/90? Who knows, I will definantly give you a call when I get these things sold.
Old Oct 9, 2007 | 08:43 PM
MikeM@ECS's Avatar
MikeM@ECS
I'll call you tomorrow for some advice on where to get good head.
Old Oct 10, 2007 | 12:58 AM
BATM4N's Avatar
BATM4N
Old Oct 10, 2007 | 12:40 PM
Cruise-In V Veteran
This is a Corvette Forum, take a hike junior
Old Oct 10, 2007 | 01:49 PM
nickolbag's Avatar
nickolbag
Bob K.
Mike definitly knows what he is doing. Cartek heads are track proven performers.
Old Oct 10, 2007 | 08:15 PM
MikeM@ECS's Avatar
MikeM@ECS
To Head question
